RPM doesnt work ='(
Old Dec 30, 2011 | 12:06 AM
reevex062's Avatar
Default RPM doesnt work ='(
Hello,
May anyone please help me with suggestion on how to fix this please? Here is what is wrong, I did an engine swap on my totaled (rear impact so the engine is 100% fine, engine start and everything work fine after the accident) 98 GSR into a 00 GSR shell.
After the swap everything work fine except for the the RPM gauge ( doesnt move at all). Every other gauge (speedometer, fuel, etc...) and lights work on the tachometer...
NOTE: I use my 99 GSR to test, it is working perfectly fine.
Here is what I've tried so far:
1) Took out that gauge and install it into my 99 GSR >>>> everything on the tachometer work fine so I've conclude that its not broken.
2) Thought the Distributor was broken or the dizzy wire was not plug in. >>>> Checked >>> Distributor and wire are working fine >>>>> RPM gauge still doesnt work :frown:
3) check the VSS and everything is plug in correctly and tightly >>>> RPM still dead =.="
Thank you in advance!!!
Old Dec 30, 2011 | 12:34 AM
mouab18c1's Avatar
Default Re: RPM doesnt work ='(
Have you checked your ground wire on your thermostat housing?
Old Dec 30, 2011 | 01:36 AM
HondaPartsHero's Avatar
Technical Hero
OBD2b doesn't have the tach signal wire at the dizzy harness, you have to splice it to the drivers side tach signal wire
http://www.team-integra.net/forum/11...-ecu-swap.html
ek souljah
Oct 19, 2014 11:58 PM
Mfoehrkolb
Sep 9, 2008 12:19 AM
94allmotor
10
Nov 3, 2007 08:45 PM
bombers_2007integra
Oct 10, 2006 04:21 PM
