FS: OEM main & rod bearings H22/F22
Old Dec 28, 2011 | 04:09 PM
SCR ZC-T's Avatar
Default FS: OEM oil pump, main & rod bearings H22/F22
H22: 92-96
F22: 94-97
All brand new not opened
ROD BEARINGS:
(6) 13214-ph3-004 BEARING C, CONNECTING ROD (BROWN)
(2) 13213-ph3-004 BEARING C, CONNECTING ROD (BROWN)
MAIN BEARING:
(4) 13323-pt0-003 BEARING C, MAIN (GREEN)
(5) 13321-pt0-003 BEARING A, MAIN (BLACK)
I think I lost one that's why there are only 5 and not 6
(2) 13331-pt0-003 thrust bearings
post or PM with offers for the bearings.
OIL PUMP
I also have bnib oil pump.
part number: 15100-pt0-030
Oil pumps are not cheap, but there are cheap quality ones out there for $100. Please do not compare those to a honda pump.
please make a reasonable offer
Old Dec 30, 2011 | 06:54 PM
SCR ZC-T's Avatar
Default Re: FS: OEM main & rod bearings H22/F22
ttt
Old Jan 17, 2012 | 01:01 PM
SCR ZC-T's Avatar
yup just some boring bearings and an oil pump .. make an offer
Old Feb 17, 2012 | 08:02 AM
SCR ZC-T's Avatar
blah blah blah
Old Feb 21, 2012 | 08:12 AM
SCR ZC-T's Avatar
anybody building a G23 that needs new oil pump? here you go.
Old Feb 25, 2012 | 05:44 AM
SCR ZC-T's Avatar
what is everybody walking now cause of high gas prices?
Old Mar 1, 2012 | 06:49 PM
eg6-jarhead's Avatar
will that pump work on a 99 a4 block?
Old Mar 6, 2012 | 01:30 PM
SCR ZC-T's Avatar
Yes it will will BUT the CKF sensor will bolt up to it.
If you are using an obd1 ecu then the CKF sensor is not being used and all is good.
jdm_rb20
20
Mar 13, 2013 06:53 PM
SoHc94
Nov 3, 2008 04:24 PM
Marcpb443
Nov 3, 2006 01:00 PM
Sprayteg
Feb 14, 2004 06:03 AM
HotWheelz
Nov 2, 2002 10:01 AM
