90 integra gsr cant go more than 4000 rpms
Old Dec 27, 2011 | 08:17 PM
ahh_yeahh's Avatar
Default 90 integra gsr cant go more than 4000 rpms
I have a problem.with my car. Ill like to.know if somebody can help me.
I did the spaw in my car some weeks ago n i cant go.more than 4000 rpm
the car doesnt have check engine n everything is odb1. Im using a gsr ecu.
I changed the ecu p28 n still doing the same.
Old Dec 27, 2011 | 08:35 PM
ahh_yeahh's Avatar
Default Re: 90 integra gsr cant go more than 4000 rpms
Nobody????
Old Dec 27, 2011 | 09:37 PM
GodlikeGS-R's Avatar
I think your running in "Limp mode". ecu is trying to protect the engine from lean condition or something. Just a guess.
Old Dec 27, 2011 | 10:49 PM
01oemTeggy's Avatar
check your cat. probably F+cked up. just gut it out, its why mine woudln't rev past 4500 rpm afterwards it worked.
Old Dec 28, 2011 | 01:25 AM
HondaPartsHero's Avatar
Technical Hero
What distributor and injectors are you using?
Old Dec 28, 2011 | 05:53 AM
ahh_yeahh's Avatar
I try open headers with another ecu. But when i put my p28 the car does the same at 5.5 rpms. Also i took the vtec wire n still doing the same. This car had a b16 motor but i never had that problem with the b16 it just happen when i swap the gsr.......
Old Dec 28, 2011 | 05:58 AM
ahh_yeahh's Avatar
Im using the same ecu the same distributor etc. The car doesnt have leaks oil is new.
Old Dec 28, 2011 | 05:59 AM
ahh_yeahh's Avatar
Im using a ls dizzy n obd1 gsr injectors.
ericstypeR27
Engine Management and Tuning
Jan 8, 2009 05:52 PM
ericstypeR27
Jan 7, 2009 10:34 PM
jdmjin
Aug 31, 2007 02:04 PM
jsull.
11
Dec 9, 2005 03:08 PM
hybridmoose
Apr 24, 2003 03:50 PM
