does a d16a6 motor bolt to a d15b7 trans?
As title says will a d16a6 motor bolt.to a d15b7 auto trans cause were. Doing a quick POS. swap but having trouble matting the two together
yes it does but what chassis are you putting it into? the d15b7 is obd1 motor and the d16a6 is obd0....the d16a6 will drop into a obd1 chassis with little modification....the d15b7 will not drop into the obd0 chassis easily as you would need to do a cable to hydro convertion
