Air/Mix motor for 03 acura
Hi, I'm new to this forum. I have a 2003 Acura TL-S and recently was having trouble with the heater. The A/C works fine but when I increase the temperature, the heater does not kick in. The fuse is fine. After browsing around, it sounds like it could be my air/mix motor or the mode motor and was trying to get access to it to test it. I am able to remove the passenger fuse box panel and then the glove compartment but after this, I'm getting stuck and I don't see anything obvious that looks like the heater core/radiator. Does anybody know where I could get some instruction on how I would be able to access the air/mix motor? Do I have to take off the panel surrounding the glove compartment? Any advice would be greatly recommended!
