zc fuel leak
hey guys i have an ef with a small fuel leak. The car started smelling like gasoline one day after i turned it on. I found the source and its coming from behind the injector. Im not too technical so sorry if i cant explain it too well. The leaks coming from the seals behind the 4th injector. The thing is my ef hatch came with a jdm zc swap so i want to kno what part do i order? I kno the zc is a mix of honda motors and i dont wanna get the wrong parts. Or are all d series fuel rails/ injector seals the same? Any help would be apreciated guys thanks
its a dual cam sorry i never mentioned, im gonna replace them all just to be safe. So can i just use any d series o rings or does it have to be a specific model? Can i just request 88-91 civic o rings at oreily's?
I think dohc zc is an integra engine, so o rings need to be off that one
but they're all pretty much the same.
go to the store with an injector or o ring and they'll sell you 4 o rings for anout 4.00 dollars. They need to be specific for fuel
CAUTION;
be careful when inserting the injectors into there holes, don't force it because you can break the cap at the end
CAUTION;
pelotudo
Sep 26, 2002 08:59 PM
