EF Sedan parts needed for b18b swap?
Here's the thing, My knowledge in swapping motors is not all that good and im also new at it.
My question is what other parts i need to swap my ef sedan?
I have a B18B motor and i also have a hydro tranny but for the tranny i heard converting a cable to hydro is complicated, so imma try to get a cable tranny instead. Now besides the tranny and the motor what other parts i need to do a swap?
If you guys got tips/tricks on swap pls do tell?
^^^ Why would you have him start there when there is already someone that has something SPECIFICLY for the 4th generation?
Here OP - this actually gives you what you need for the '88-91 models...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
It's because nobody takes care of this Forum anymore. All the moderators are never on in here and the person who runs the FAQ isn't here that often either. There are plenty of links that should be removed that don't work as well as added but get lost with time unfortunately. The few that care won't be granted Moderator due to needing to be in the "inner circle".
MdMaxPluR
Nov 11, 2010 02:16 AM
eumoria
Sep 21, 2004 01:43 PM
