What to do now??
what was the reason for the sleeve cracking? there appears to be some signs of detonation on the pistons if i am seeing it correctly.
Yea, it's called re-sleeving lol (I'm sure you know that), not much else you can do. Hope you got some dough bra.
2 options.
1 resleeve
2 buy new bare block or assembled shortblock.
2 options.
1 resleeve
So if I go with a with a new block how do i know this isn't gonna happen again? I thought by getting it resleeved it will be alot stronger then normal....
Yea a little bit of positive pressure isn't going to cause a sleeve to crack. And getting it sleeved will make it stronger, but it's gonna cost you a dickload of money. Like stated above, you aren't sure what caused this, but my guess is that there was already a hairline crack forming just from being an old engine, but if you buy a new block just make sure cylinder runout is in spec, basically a perfectly good factory sleeve is not going to do that, even with a little positive pressure ("boost" as they call it).
