CamberKit
Old Dec 26, 2011 | 07:21 PM
fin781's Avatar
Default CamberKit
So skunk2 is the only front kit i can find, buddyclub and blox make reasonably priced kits, but only for eg-ek. now will the upper a arms interchange with a crx or if i recall correctly, there wider.
Old Dec 26, 2011 | 08:20 PM
zrickety's Avatar
Default Re: CamberKit
Revo makes a kit too, similar to skunk2. I would sell mine, pm me if you want them.
Old Dec 26, 2011 | 08:22 PM
harryrat's Avatar
https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
read this before purchasing camber kits
Old Dec 26, 2011 | 11:30 PM
Stunna MIKE's Avatar
Honestly I wouldn't run a front camber kit. I have had horrible experiences with them. The stupid Allen bolts that hold the camber kit from moving take like 7lbs to torque down. I have had both my camber kits break on me and I nearly ended my life. There really is not much negative camber when you drop your car to a functional height. Just get an alignment and set your toe. That's what eats tires NOT camber! If you want me to explain how my camber kits broke let me know. I'll explain better from a computer. Takes to long to type on a phone
Old Dec 27, 2011 | 04:18 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
There are too many variables to just say "Oh it's only toe not camber"... Just like that thread was updated with a little more information it's still misleading. Not everyone uses the stock tire sizes, seasonal/season, hard/soft, ect. tires. All of this changes how a tire will wear. To me, only getting 20-30k miles out of a set of 50-60k mile tire is completely unacceptable. Say what you will but if you actually drive the vehicle hard you will see how much camber also destroys tires. Given, it's not as bad as toe, but that's like comparing apples to oranges. If you understand what each does - then you understand why and how they are unrelated.
KCUF_DB8
Suspension & Brakes
Feb 23, 2010 05:30 AM
91EF919
Jun 30, 2009 04:11 PM
ef-b16sedan
19
Mar 29, 2007 06:12 AM
crx1009
Apr 5, 2006 09:57 AM
vteg
May 10, 2002 07:04 PM
