oil light wont go out
You need to hook up an oil pressure gauge (tester) in place of the oil pressure switch.
With the engine warm @ idle (750-800rpm) you should see 10psi minimum for oil pressure. Then bring the engine RPM up to 3000 and you should see 50psi minimum.
replaced oil sendin unit,plugged in tight,full of oil,light came on @ 2 qts low filled and reset but light stays on.how do i check oil pressure on this 93 honda accord 2.2L?
