Steering knuckle and lower control arm problem.
Old Dec 24, 2011 | 12:52 PM
louevilhatch's Avatar
Default Steering knuckle and lower control arm problem.
I just replaced my driver side axle in my 89 hatch with a b16 swap. I used a 90-93 integra axle. For some reason I can't get the lower control arm and steering knuckle lined up to save my life. The axle is all the way in. I checked the length of the axle compared to the other and they are the same. I'm about 1/4 inch away from it dropping in. Any suggestions?
Old Dec 24, 2011 | 01:19 PM
v4lu3s's Avatar
RTFM
Default Re: Steering knuckle and lower control arm problem.
possibly not all the way seated on the inner joint
Old Dec 24, 2011 | 02:23 PM
crvtectim's Avatar
Did you remove the dust shields from the axle and hub?
Old Dec 24, 2011 | 02:24 PM
I did not. Am I supposed to?
Old Dec 24, 2011 | 02:39 PM
I also read that 90-93 axles won't work with dx knuckles. is this true? and what do these dust caps look like?
Old Dec 24, 2011 | 02:50 PM
crvtectim's Avatar
Yes, remove the dust shields. You will need to pull the axle back out of the hub to see it. You can pry it out with a screwdriver. Not sure about the axle fitment on DX. I've always had SI or converted LS.
Old Dec 24, 2011 | 03:55 PM
Anyone know where I can get pics of these dust shields?
Old Dec 24, 2011 | 06:48 PM
zrickety's Avatar
Google 'dust ring honda' and it's the second image. Behind the knuckle where the axle comes in, it's a thin metal ring you can pry out. Do this on both sides and you should be good.
Old Dec 25, 2011 | 09:25 AM
Well the dust ring was already out. So I'm still stuck. Any other suggestions?
Old Dec 25, 2011 | 09:31 AM
crvtectim's Avatar
Hmm, is the axle completely bottomed out in the hub and intermediate shaft?
Old Dec 25, 2011 | 11:10 AM
zrickety's Avatar
What intermediate shaft are you running? It should be stamped SK7. If not, you'll need different axles.
Old Dec 25, 2011 | 11:47 AM
It's all the way in on both sides. How do I tell what IS I have?
Old Dec 25, 2011 | 11:48 AM
Nvm stamped. I'll go search for it. Thanks for being patient guys.
Old Dec 25, 2011 | 03:54 PM
zrickety's Avatar
If you have the Sir (jdm) intermediate shaft, you need to build a custom driveshaft using an 88-89 Integra axle with a 90-93 Integra outboard CV joint.
Or find the SK7 intermediate from the integra, and use regular integra axles.
Old Dec 26, 2011 | 02:48 PM
I bought the motor from hmotors probably 4 years ago and never have had a problem until now. So, now I know what I have to do. Thanks guys.
Old Dec 26, 2011 | 03:34 PM
H22BB6's Avatar
Is the car evenly jacked up? If not it could be the sway bar applying tension and pushing the LCA down. If your car has a sway bar.
Old Dec 26, 2011 | 04:09 PM
Yea it's jacked up evenly.
Peteypablo17
Transmission & Drivetrain
Feb 10, 2013 05:31 PM
bigdogc
Jul 19, 2005 04:37 PM
shorty0o29
Feb 24, 2004 09:31 PM
serious
Mar 19, 2003 05:19 PM
Malice
Jun 21, 2002 09:08 PM
