91 problem
Old Dec 23, 2011 | 07:52 PM
rickt84's Avatar
Default 91 problem
My ignition switch went bad this morning, so I called the junk yard to see what they had in stock. I have a 91 5 spd, and all they had was a 91 automatic, but works none the less, just has an extra harness for the neutral/safety switch.
So I replace the switch, starts without a problem, but NOW, I have no radio, and no cigarette lighter socket.....
All fuses have been checked, none are blown.
Any ideas?!
Old Dec 23, 2011 | 08:59 PM
TheRealTegger's Avatar
Default Re: 91 problem
Better check again. You've probably got a blown 10A fuse in the under-dash fuse box. Check in the upper-most of the four rows of fuses.
Old Dec 24, 2011 | 07:07 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^, and do not just eyeball the fuse, test it or replace it with new or known working one.
Question, does the blower motor work, if not, check the main acc. fuse, upper right of fuse box under plastic clip/cover
It is the big green one, [the clip/cover is missing of this one].
Here is a diagram.
Good luck and merry hoho.94
dc4teg95
Jul 27, 2013 02:07 PM
unrestrictedkc
Aug 27, 2009 01:36 AM
1991legendLS
Audio / Security / Video
Sep 16, 2005 09:19 AM
Joon Joon
Sep 1, 2005 08:22 AM
