Caster/Suspension issue on bigger rims
Old Dec 23, 2011 | 03:18 PM
NightxSouL's Avatar
Default Caster/Suspension issue on bigger rims
Hi everyone, new to the forum. Appreciate any advice that I can get. Recently bought a 1996 Integra LS, Automatic. It came with a 17" ADR rims and Kuhmo tires. Skunk adjustable coilovers, KYB shocks.
I notice the car pull left/right whenever i pull to a stop. Took for a car alignment, the problem still is there. Then did a full vehicle inspection. Firestone found out, the caster on the front left can't be adjusted. They said that it's because my rims+tires weren't from the manufacture. So in this case, they weren't able to adjust it to its specific measure.
Is this true with all vehicle that have bigger rims/tires? If not, how can i be able to fix my issue? Thanks
Old Dec 23, 2011 | 03:31 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Caster/Suspension issue on bigger rims
Lol @ firestone. caster is not adjustable on integras regardless of rim size. rim size doesn't determine caster either. Wtf are some of these shops smoking?
If it's only happening while coming to a stop, maybe theres an issue with one of the calipers not working.
Old Dec 23, 2011 | 09:08 PM
TheRealTegger's Avatar
Firstly, alignment issues show up when driving in a straight line, not when braking. Your problem is most likely a brake issue. Pull ALL FOUR wheels and inspect ALL FOUR brake assemblies. Rear brake issues can also cause the car to pull.
Secondly, the Firestone mechanic doesn't know what he's doing. There are only two things that are adjustable on your car (assuming OE parts): thrust-angle and toe. Neither has anything whatever to do with the wheels and tires.
Old Dec 23, 2011 | 09:52 PM
DirtyDA9's Avatar
If it pulls when coming to a stop it is brake related.
Old Dec 23, 2011 | 09:55 PM
jcuetizzi's Avatar
prob one caliper is newer than the other. pulling the car to that side.
Old Dec 24, 2011 | 10:51 PM
NightxSouL's Avatar
Hi guys, appreciate all the replies. I had my rotors and pads replaced a year ago, but before i replaced them. I already experience the stop pull left/right. If it's brake related. Do you suggest that i should take my car for a brake inspection? I never had any caliper replaced. The only suspension parts that weren't stock are the KYB shocks and SKunk adjustable coilover springs. I also have strut bars front and rear.
Old Dec 24, 2011 | 10:53 PM
NightxSouL's Avatar
LMAO at the smoking part. I guessed they were trying to sell me some story good enough to make sense.
Old Dec 25, 2011 | 08:34 AM
sengalang's Avatar
^had a similar experience.. Input shaft bearing was on its way out and tranny shop told me that its not the tranny but the wheel bearing.
I was like "wtf? your telling me that my wheel bearings are making noises when i engage/disengage clutch while the car is at a full stop?"
You can bet i got my *** outta there quick.. "Transmission Specialist (Name of shop)" my *** lol.. ended up fixing it myself the next day..
anyways, to the op.. it seems to me those firestone techs dont know anything about honda's i guess. Follow the above advice and inspect your brakes. Get back to us when you do.
Old Dec 25, 2011 | 11:35 AM
NightxSouL's Avatar
I had my vehicle inspected by midas 2 months ago, they didn't find out anything wrong with the brake. Probably it wasn't a thorough inspection.
Thanks guys, i'll have my brake inspect. Will post update.
Old Dec 25, 2011 | 01:18 PM
DirtyDA9's Avatar
All Midas did was measure pad and rotor thickness, caliper piston function isn't tested/checked during an inspection, other than them stepping on the brake and making sure the car stops lol. They are going to have to take the caliper off an physically test how well the pistons engage.
Old Dec 27, 2011 | 01:35 PM
That's not how you check to see if the caliper piston is seized. You check this way:
http://www.tegger.com/hondafaq/misc/...r-reman/01.jpg
This can be done on the car.
Here's what you're looking for:
http://www.tegger.com/hondafaq/misc/...r-reman/03.jpg
and
http://www.tegger.com/hondafaq/misc/...r-reman/04.jpg
The rust and gum is what makes the piston stick.
The ENTIRE brake assembly needs to be checked, not just the calipers.
Seized pins and stuck pads also cause brakes to pull, sometimes badly.
newfiedvdr
Nov 28, 2014 05:19 AM
BAYxlude88
Dec 14, 2008 11:00 AM
eagleclawracing
Jul 8, 2006 09:15 PM
94hondaEG
Apr 6, 2006 06:54 PM
Blazeone
Honda S2000
19
Feb 22, 2005 05:19 PM
