Quick p28 ecu and mini me swap question
Old Dec 23, 2011 | 01:21 PM
JDMhoe1992's Avatar
Default Quick p28 ecu and mini me swap question
im doing a d16z6 head on a d15b2 block. i have everything i need to do this. but i got my p28 ecu from a buddy that had a b20 swap and boosted and the ecu is chipped on chrom. would it be ok to use this ecu still for the mini me swap and get it tuned in a couple months because i dont really have money to just go blow and get a new ecu with the holidays and all.
Old Dec 23, 2011 | 02:38 PM
crvtectim's Avatar
Default Re: Quick p28 ecu and mini me swap question
You can use the ecu, but not with the tune for the B20T. Your best bet until you can get tuned would be to find a basemap for a Z6, burn it to a new chip, and install that in your P28.
Old Dec 23, 2011 | 02:46 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
No, it will probaby run bad. If it's a P28 then just cut/remove the J1 jumper header (this obviously makes it run on the stock map and bypasses the chip).
Old Dec 23, 2011 | 05:22 PM
JDMhoe1992's Avatar
ok thank you both a lot!
cyhm
Aug 5, 2014 05:54 PM
ProjectHatchEG6
Jan 29, 2011 09:54 AM
obuhmyuh
May 6, 2007 05:33 AM
skinnyeg
Jan 22, 2007 11:40 PM
MMMm Waffles
Jul 12, 2006 08:57 AM
