Cluster not working. Help
Old Dec 23, 2011 | 12:54 PM
tommi's Avatar
Default Cluster not working. Help
i took my cluster out to swap out the gas guage in favor of the 5spd one since i swapped auto to manual. now i've swapped the gauge over and none of my gauges work. is there a fuse or relay anything i can test? at first my tach was working then that stopped after i unplugged it to see whats wrong with the speedo, then the tach worked for a little then that stopped too.
now none work. i went to the j yard to grab a extra cluster but the plugs on the top and sides differed. i tried using the gauges out the j yard one and put it inside my cluster still no luck. im highly frustrated with the situation and want my cluster to work propperly.
Old Dec 24, 2011 | 09:25 AM
tommi's Avatar
Default Re: Cluster not working. Help
wow no one?
Old Dec 24, 2011 | 09:37 AM
GhostAccord's Avatar
My suggestion is to put it back to the way it was, make sure all of your connections are clean and tight. See if that does anything for you.
Model and year of your Accord and the gauges being used would also help. To be honest with you. I didn't know that there was a difference between the 5sp and auto fuel gauges. Using gauges from the same year Accord would be a suggestion.
What, if any wiring did you change when you did your 5 spd swap?
Old Dec 24, 2011 | 05:07 PM
crazymikey's Avatar
It's not the auto/5 spd fuel gauges that are different, it's actually the plugs for the wire harnesses on the 9293 gauge clusters that are different and not compatible with the 9091 clusters. Auto/5 spd makes no difference, other than the shift pattern for the auto inside the cluster.
As for the original problem...not able to help with that one.
Old Dec 27, 2011 | 06:49 PM
75aces's Avatar
I saw a post a while back. The OP suggessted to insert your key into the maintenance slot of the cluster 3x and then turn it from of to on but don't crank the engine. I haven't tried it myself.
bayFERIOroan
Feb 10, 2014 05:02 PM
SILVIC00
Apr 9, 2005 10:04 PM
-Bionic-
Apr 25, 2004 06:44 AM
Hawd
Jul 24, 2002 11:52 AM
