Parts For Sale K-Tuned JDM Skunk2 DSS
Location-Chantilly, Virginia
Greddy slightly used 13 row oil cooler with aeroquip starlite hoses. I replaced the steel braided hoses. $525
Skunk2 Composite Fuel Rail Acura RSX Type-S DC5 (02-06) BNIB $180
DA Front Hubs With Extended Studs Off My CRX $50
Custom Aluminum Radiator Stay $5
Injector Plugs I Believe Came Off My Old Precision 1000cc Injectors (Please Look Closely) $40
Megan Racing Acura RSX Test Pipe BNIB $100
K20A2 Stock 1-4 synchros 32K miles (replaced with Carbon Coated) $100
K-Tuned Universal AC/PS Delete BNIB $200
Hawk Front Brake Pads $35
Acura CL 2.3L, 4 cyl. 1997-1999
Honda Accord COUPE - 4 cyl. 1998-2002
Honda Accord COUPE 1993-1997
Honda Accord SEDAN - 4 cyl. 1998-2002
Honda Accord SEDAN - 4 cyl. 1995-1997
Honda Accord SEDAN 1994-1994
Honda Accord SEDAN - Akebono front caliper 1990-1993
Honda Civic COUPE 2001-2005
Honda Civic COUPE - Si 1998-2000
Honda Civic COUPE - EX 1996-2000
Honda Civic HATCHBACK - Si 2002-2005
Honda Civic SEDAN - DX, EX, GX, LX 2001-2005
Honda Civic SEDAN - EX 1997-2000
Honda Civic SEDAN - EX, LX - w/ ABS & A/T 1996-1996
Auto Meter Ultra Light Carbon Fiber Boost Guage 2 1/16" Part #4703-$30
K20Z Cams (I Believe Z3 Cams) $75
02-04 RSX-S Stock Injectors (I Think Ones Broken Or Missing A Part) $75
Skunk 2 Spring Base Kit BNIB $20
02-04 RSX-S Stock TCT (Timing Chain Tensioner) 32K $25
Blue Wire Loom $5
JDM Honda Del Sol Cluster $75
1994 Acura Integra LS Automatic Cluster $30
5Zigen 16" Center Caps Off FN01R $25
Faze Guages A/F Ratio-Oil Pressure-Volts-Temp
Mitsubishi Lancer Evolution (EVO) OEM Ballasts $75
Apexi Turbo Timer (what you see is what you get) $40
8 Skunk 2 Extended Wheel Studs Used $25
DSS Stock CRX K-Swap Axles $200
AEM Cold Air Intake Cut To Be A Short Ram Intake (Used In My K20 EG) $50
Custom Aluminum Intake With Velocity Stack That Comes Out Of The Drivers Side Headlight (used With A JRSC And NOS) $50
Type R Front Strut Bar (Unsure If Its Real Or Not) $25
NOS Sneaky Pete System $125
Blue Wire Loom $5
S2 INSIDER
43
Sep 19, 2004 08:36 PM
f@sth@tch89
Jul 21, 2003 08:19 AM
