JDM Project Kics R40 Open Ended Locking Lug Nuts Neo Chro (Extended 1.5mm)
Old Dec 22, 2011 | 03:47 PM
pearlwhitecrx's Avatar
Default JDM Project Kics R40 Open Ended Locking Lug Nuts Neo Chro (Extended 1.5mm)
Ok guys I only have 10 of these with the key, not a full set of 16
Pick up in alameda or oakland call or text 510-387-8880 throw me an offer
once again, only 10
They are in rough shape but still work, I never used them... They came with a set of used wheels I got
if you dont know about these:
Project Kics feature a unique seven-sided, heptagonal lug nut is that each lug consist of 2 pieces, where the top of the lugs spin freely from the tapered centering ring. This ensures a much tighter and precise hold than traditional lug nuts. It also minimizes the chances of scratching your wheels. Made of lightweight composite materials, these open ended lugs fit on both standard studs as well as extended studs. The entire set weighs just under 2 lbs! Highly recommended for both street and track enthusiasts.
*Super light-weight thin-wall contruction using strong light-weight OEM quality materials*
*Oversized and taper seat to ensure best contact*
*External drive by popular 17mm hex for easier installation*
*Full stud engagement and can accomodate long racing studs*
*Reliable and stronger than aluminum racing nuts*
*Japan patented (No. 1192260) and USA patent applied*
*Lug body produced by Cold-Forged SCM-435 material*
*Attached rotating taper-seat made with A7075-T6 aluminum and ultra-hard alumite finish*
Old Dec 25, 2011 | 11:39 AM
low&slow's Avatar
Default Re: JDM Project Kics R40 Open Ended Locking Lug Nuts Neo Chro (Extended 1.5mm)
hum much shipped 2 92335?
Old Jan 25, 2012 | 10:20 AM
4NLINE UNLIMITED's Avatar
SOLD, Thanks Ryan.
once again, only 10
raffaelli
Aug 11, 2011 08:39 PM
BLK2DOOR
Apr 13, 2010 09:36 PM
ATS*Mark
Dec 3, 2005 10:56 AM
JPineda
May 17, 2004 06:00 PM
civicrights
Oct 16, 2003 05:48 PM
