RADIATOR FAN NOT WORKIN
i got a civic eg with a ls motor in it. The cooling fan doesnt work, i tried jumping the fan switch with a paper clip and it still didn't come on. The fuses isn't burned out. im guessing the fan is broken?
the fan switch is on the t-stat housing if you remove the connector and jump it with a paper clip the fan should come on with the key on, if it does the relay is good and the switch is bad. if it does not come on relay or wiring issue
There's something else you might want to check.
My car's got a cooling control unit that is located inside the car, near the driver's seat.
When I first bought it this unit wasn't working properly and the fan only came on once the key was pulled from the ignition, never when the engine was running.
Can it be that you could be having the same problem ?
Also, in my car too there are also a number of sensors that read engine temperature in several parts of the motor. You could try and get a schematic to you can verify they're all good.
xTomei
10
Jun 7, 2010 06:02 PM
