Alternator output too high (17v) help
Old Dec 22, 2011 | 08:45 AM
olskurida's Avatar
Default Alternator output too high (17v) help
I rarely post, but this problem got me.
Car- 1999 Civic Sedan (Canada)
Engine - 1999 Integra LS (US)
ECU-OBD1 LS
Problem - I just finished the swap a few days ago, but I cant figure out why my alternator is pushing our 17v, which is way too high. I thought it was the voltage regulator inside the ALT was bad so I swap it out for a new Alternator and it still does the same thing. Thought it was the ELD so i swap in a US Fuse box (with the ELD) wired it up, tested the ELD, works correctly, 5v when nothing is on, drops as I start turning stuff on.
Funny thing is if I unplug the alternator connector the voltage drops down to 14.4v. I could run like that but I really want to figure out the problem.
Does anybody know which wire (coming from the ecu) tells the ALT to engage? i know its either the WHT/GRN (ALT C) or WHT/RED (ALT FR)wire.
Your thoughts?
Old Dec 22, 2011 | 01:57 PM
apexi_rsx's Avatar
Default Re: Alternator output too high (17v) help
white and red i believe iis the alternator control signal.
Old Dec 22, 2011 | 02:24 PM
olskurida's Avatar
been looking around WHT/GRN is Control. read a few troubleshooting procedures and they all talk about the WHT/GRN wire.
Checked all wires and made sure there is connection and no short, everything checks out.
Big white wire is showing the alternator output
Blk/Yel- is battery voltage
Wht/Blu (to cluster charge light) - is battery voltage
Wht/Red (ALT FR)- shows 5volts
wht/Grn (ALT C) - not sure how to test this
starting to wonder if its the ECU...
Old Dec 22, 2011 | 02:26 PM
olskurida's Avatar
so i de-pin the wht/red wire from the alternator connector. Alternator still pushes out 17v
Old Dec 27, 2011 | 06:59 AM
jillnill's Avatar
borrow an ecu & replace it. if fault gone then u know wat to do, otherwise check wiring as per service manual
H Series Garage
Mar 23, 2017 07:13 PM
ThE HeLLRaZoR
Aug 16, 2012 10:50 AM
Dark_Teg
11
Mar 28, 2009 09:32 PM
