h2b build how much power??
i have a euro r h22a motor and i was wondering how much power would
11-5-1cr pistons, rods, with skunk2 pro 2 cams with valvetrain make???
is going 12-1cr or higher worth the extra money??
I have a friend with a JDM H23A stock block with K series RBC intake manifold, SSR Header, Blox B cams and supertech valve train and he makes 240whp. So i assume with your compression bump you should be able to make a over that atleast.
Yes and not a replica and authentic one. Here's his setup. http://www.hondatuningmagazine.com/f...sir/index.html
It's more cost effective to build a 350 whp turbo h22 than an all motor 350whp. You didn't say a power goal. What's cheaper than a turbo or all motor build? N2o
We're in the same position, I live in Canada. Lol
Cams valve train ect
Then u add the cost of the turbo or a header
What's going to last longer??
270+ wheel is putty easy with those parts listed above
He said cost effective way to make power. He didn't say a power goal or what the car was for. I was just using that as an example it would be cheaper to make 350 whp with a turbo setup on stock internals than it would be to build it 350whp all motor
Sorry my tuner jus told me its 12-5-1cr arias pistons that he ordered for me and would the pro 2 cams work well with that
i hope your sleeving the block cuz theres no piston higher than the mahles 11.5:1 that will work with the FRM liners, so if your tuner ordered you 12.5:1 your gonna need to sleeve the block.
xkhalil333x
Jun 21, 2014 01:57 AM
uhhmaysing
13
May 28, 2014 06:56 AM
Master Type R
10
Jan 17, 2008 05:41 PM
rough_draft
15
Jan 19, 2005 12:27 AM
