help: 91 2 dr DA cigarrete power outlet wont work
Old Dec 21, 2011 | 06:53 PM
604DB1's Avatar
Default help: 91 2 dr DA cigarrete power outlet wont work
so everhything is connected checked all the fuses its goood ....things that dont work is the interior rear light cigarrete outlet and my hazzards dont work is there any more hidden fuses that i should know? THANKS!
Old Dec 21, 2011 | 08:49 PM
fcm's Avatar
fcm
Old Fart
Default Re: help: 91 2 dr DA cigarrete power outlet wont work
By "interior rear light" I assume you mean the hatch light.t is on the same fuse, [Fuse 14 -15A, under dash fuse box] as the dome light, if dome light works, then the problem in the rear must be the bulb, or a wiring problem, [test the white/blue lead for power].
The hazard lights are on a fuse in the engine bay fuse box, fuse 34 on CDM G2s, [sorry, do not have a USDM G2 fuse number, but it's a 10A].
If your signal lights work properly then everything after the hazard switch is good, [relay, wiring, bulbs] so either the switch is bad, the hazard light fuse is no good or there is a connection problem, remove hazard switch and test for power on the white/green lead, if good, the fuse and connections are good, the problem is the switch.
To confirm turn the hazards on, test for power on the green/white lead, most likely there will be none.
Replace the switch.
Not sure about the lighter, but if it has a white/blue power lead, then it is most likely on the dame circuit as the dome, [rear] light. 94
Old Dec 22, 2011 | 04:02 AM
604DB1's Avatar
Replace the switch.
Sorry I stated wrong. Of that hatch light the middle one lol I'm a noob lol
But thanks for the input will Try what u have stated to do!
Canucksfan101
Dec 31, 2014 03:02 PM
dc4teg95
Jul 27, 2013 02:07 PM
traxxasx
10
Aug 10, 2009 01:28 PM
ser13
Dec 26, 2007 12:58 PM
SpeedoKing
Jul 18, 2007 06:57 PM
