My car was stolen, Not sure where to start (ignition key/column))
My 95 Integra was stolen. The part where u put the key is all jacked up. I'm assuming I need a new ignition key. Do I buy the whole steering column or just the ignition part? Here's some pictures. I'll probably bring it to the shop to have someone fix it or find someone on craigslist or something.
Ditto the above^^^ hard to say, my guess is a "lock set", #1... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal or at the very least the key cylinder/steering lock housing and new key cylinder.
Best bet, [cheapest] is find one at a PicknPull and just buy a cylinder and keys, or have a cylinder "keyed" to your keys. 94
What fcm said. Had the same problem (stolen from previous) - used the spare to provide an intact lock set and part of the wiring harness that had been damaged.
Damn, sorry to hear. You will have to have someone look at it and tell you what needs to be replaced. Back in 02 when they did this to my fathers 00GSR it cost $3000 through insurance. They took the shift **** and owners manual as well. The steering colum was really messed up.
it's a few hundred to fix from the looks of things, the new ignition cylinder will come with a key. at that point you can either pay and have the locks all re keyed or just use two keys like a GM car would be.
if you don't have a garage buy the $20 harbor freight battery powered motion detectors. put one in the car and one by your bed. for those of you without a garage this is the cheapest alert system you can get
b18cEK
10
Apr 6, 2006 06:23 AM
