HELP! 1991 Honda Civic Wagon starting problem !
HELP! Just got a 1991 Honda Civic wagon and it was running like a champ for the first two weeks (no problems at all) but then all of a sudden the car wont start anymore.
When I try to start it the car wont even do a noise at all ... not even a crank its like if the engine is dead but all the electronics work (radio, automatic door belts, all lights) and have no check engine light on.
I checked all the fuses and they are all fine. Also I changed the main relay and battery and still nothing
Any suggestions on what can be the problem?
does it crank? if not Then its your starter. Try banging or hitting it. It should start right up.
If it cranks. Check for spark.
No spark then its your distributor.
auto/5spd? if its 5sp it might be the clutch sensor. some dont have em but my 91 civic does. if that sensors bad itll be like not hitting the clutch when u try to start it. think its near the clutch peda; but i cant say for sure. never had to mess with them on hondas
auto it might be the neautral switch. its at the shifter itself i belive.
other then those it can be a bad starter or the wire that runs to the starter.
To test the starter get some wire hook it to the starter and touch the other end to the pos battery post if it doesnt turn the starters bad. I put a starter button on my 91 always starts.
Just follow your clutch pedal up and you should be able to find it. Many times the rubber stopper that presses against the switch breaks off and ends up in your floorboard. If that's the case for you, use your finger to press the end of the switch in and try starting the car. MAKE SURE YOU'RE IN NEUTRAL!
The car will crank in gear with the switch bypassed.
If it is a 5sp.
Check on the floor board for little blue pieces of rubber.
The look at where the clutch switch is located. If it goes through the hole in the pedal assembly then the little rubber piece is missing and will not let you start.
Pretty easy to fix with 10mm bolt or using the factory rubber part.
It is same as the brake pedal switch stopper.
Ok, I'm starting to suspect a bad ignition now. The tumbler inside wears with time. Eventually, it cannot complete the 12v circuit needed to start the car.
You can see if the starter is capable by turning the ignition to on, with the car in neutral, and jumping the hot to ground on the starter. I've been stuck having to do so before with a screwdriver lol. It works though, unless your starter is bad.
