water/steam out tail pipe (not blown HG) 91si
Old Dec 21, 2011 | 03:15 PM
skill178's Avatar
Default water/steam out tail pipe (not blown HG) 91si
pretty much said it all in title, dont think itll make a diffrence but i got a sohc ZC block with a a6 head. smoke/stea, comes out tail pipe at idle like its cold even after warmup. longer you set at a idle the worse it is. not losing coolant so i know it aint water from the block and its running as normal as it can for not having an adjustable cam. just looks like its smoking like a bomb when you drive it and i hate that because this car hasent smoked since i got it
Old Dec 21, 2011 | 08:14 PM
skill178's Avatar
Default Re: water/steam out tail pipe (not blown HG) 91si
and ideas???
Old Dec 22, 2011 | 01:12 AM
TeamRedline89Hatch's Avatar
My LS swapped hatch is doing the same thing. I had a small coolant leak from the iacv dripping onto the header but I fixed that about 3 weeks ago. Still smokes like hell :/
Old Dec 22, 2011 | 05:22 AM
gringo7718's Avatar
Coolant or oil is getting into one of the cylinders and burning. If you are not losing coolant.......then that means oil. But oil burning is pretty unmistakable. So are you sure you are not burning coolant?
Old Dec 22, 2011 | 06:13 AM
janz3n's Avatar
oil- blue smoke
coolant - white smoke.
pretty simple.
smell the smoke. if its sweet smelling its coolant. also depending on where you live, if its cooler out the exhuast will be visible because the exhaust is hot and the air is cold, same reason fog exists.
Old Dec 23, 2011 | 12:46 AM
skill178's Avatar
Originally Posted by janz3n
oil- blue smoke
pretty simple.
its this ^ but it usely stops when the car warms up and mine gets worse. plus water drips out...
ITS NOT COOLANT OR OIL!!
Old Dec 23, 2011 | 04:30 AM
BlackEM2's Avatar
i think i know what ur talking about. my expedition does it...runs like a champ always wondered y this "water" drips from the tail pipe
Old Dec 23, 2011 | 05:07 AM
90civic-ZC's Avatar
Water is going to drip out of your exhaust, it's condensation from the hot combusted exhaust that's being pumped out by the engine. Some turbo set ups do it even more therefor they're more **** to rusty piping. Do a compression test and one of them dye test in your coolant. If they're both fine then stop stressing yourself. Everything sounds normal for you, like one guy said, it's winter so the hot exhaust in the colder winter air is gonna be more noticeable. Especially when going down the road (due to more throttle).
Old Dec 23, 2011 | 05:13 AM
90civic-ZC's Avatar
Old Dec 23, 2011 | 05:49 AM
CWBETB's Avatar
True, my turbo setup leaves a puddle after I start it up. Its like a slobbering dog. Stainless Steel is your friend
Old Dec 23, 2011 | 05:20 PM
zrickety's Avatar
Condensation is very common when it's cold outside...
Old Dec 23, 2011 | 05:51 PM
janz3n's Avatar
if you know its not coolant then obviously theres nothing wrong and its just condensation like was mentioned already.
Old Dec 27, 2011 | 02:28 AM
skill178's Avatar
why would i be able to to see trails of water running from under my car if it was just condensation? theres way too much water to just be condensation
Old Dec 27, 2011 | 05:07 AM
90civic-ZC's Avatar
Then do a dye test dude....if it'll make you feel better. Atleast if you do, you'll get a true diagnosis answer. I mean, all we can do is sit here on the other side of our computers and tell you what we know. It's up to you to do the work or just disregaurd everything we say.
Old Dec 27, 2011 | 05:11 AM
Spug's Avatar
If you KNOW it's not coolant or oil, then what can you possibly be leaving a trail of besides water?
mynameizstitch
Aug 17, 2008 04:35 AM
thesoundofturbo
Apr 3, 2008 07:41 AM
garnet
Oct 6, 2007 02:02 PM
blumpfish
Jun 18, 2006 09:23 PM
ghostskinner
Mar 5, 2006 07:18 AM
