HOW TO JUMP FAN SWITCH?
its the fan switch connected to thermostat. im trying to jump that. No a/c 94 eg 98 ls probably obd2
Set your multimeter to DC volts. Turn the ignition key to "II". Now see if the colored wire (not the black one) has voltage to ground. If NOT, check for a blown 7.5 amp fuse in the under-dash fuse box.
With the connector unplugged, and with multimeter set to ohms, check to see if the black wire has continuity to ground. If NOT, then the fan relay can't close.
i think autozone sells fan switches for like $30 or sumthin..... the only time i do the jump is if im at the track.
http://www.autozone.com/autozone/par..._176020_11944_
You're not supposed to jump that. That turns on by itself at 200F.
"if not then the fan rely can't close"
then that means relay buggerd?
The fan relay is closed (carries current to the motor) when the fan switch closes. The fan switch is the one on the thermostat housing.
Once the relay closes, current flows to the fan motor and then to ground. There are several fuses and connectors in between.
TheOnlyBobaFett
Aug 23, 2013 05:10 PM
maglites94
Mar 10, 2012 07:40 PM
Lloyd Xmas
Apr 14, 2010 09:21 AM
