Ls swap issues
Old Dec 21, 2011 | 01:13 PM
gsxr-t-bag600's Avatar
Default Ls swap issues
Hey i have a 88 crx si with a 96 ls motor swap the car is just now running but everytime i start it i have to rev it up myself to keep it from shuting iff until it warms up then it iddles fine, i removed and cleaned the iacv to have the same results, i took it on a test drive and the car is realy jumpy at low rpms almost like im pressing and letting off the gas repeatily then ince in highr rpms its fine, also i noticed the main relay spark once while goin down the rd, if anyone can help that would b great im just trying to have a clean good running dd
Old Dec 21, 2011 | 01:17 PM
accordin 2 me's Avatar
Default Re: Ls swap issues
mine was doing that because of my o2 sensor. got a fresh basemap from phearable.net and i can only assume it had an o2 delete because the problem is gone
Old Dec 21, 2011 | 02:03 PM
well idk i bought a new 1 wire 02 could the iacv just be bad?
Old Dec 21, 2011 | 02:56 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You never said what ECU and OBD you had...
Old Dec 21, 2011 | 03:37 PM
crvtectim's Avatar
Sparks from the main relay... dern!
Old Dec 22, 2011 | 04:38 PM
The motor and ecu both came out of a 96 integra ls and its an obd1 swap
Old Dec 22, 2011 | 05:55 PM
i swear i didnt read the sparks part. sounds electrical now.
Old Dec 22, 2011 | 06:18 PM
crvtectim's Avatar
96 motor/ecu does not = OBD1
Old Dec 22, 2011 | 07:57 PM
also true.
Old Dec 22, 2011 | 08:16 PM
10psiLsEf2's Avatar
Pull the intake tube off and look inside the throttle on the left wall theres a Hole (this runs to the IACV.
Start the car and put your finger over the hole. if theres no sucksion then its a stuck IACV.
If there is sucksion then it still might be a bad IACV ..
any codes?
Old Dec 22, 2011 | 10:05 PM
///Mathew's Avatar
any codes?
LOL....suction?
Old Dec 23, 2011 | 09:41 AM
Ok ill try that, what would be making the car so jumpy at low rpms
Old Dec 24, 2011 | 12:30 PM
10psiLsEf2's Avatar
Originally Posted by ///Mathew
LOL....suction?
yea i was blown!!! lol
10psiLsEf2's Avatar
same thing IACV.
joshd_bh
26
Sep 6, 2012 07:56 AM
rkn527
May 12, 2003 09:02 PM
WickedPerform
May 14, 2001 01:40 PM
