Spoon Mirror Info
My stock mirrors are about as messed up as they are going to get, I did some searching but didnt get all the info i needed.
Arent these designed for RHD cars, so visibility is going to be reduced? I read something about glass cutting, was confused. And also, any wiring problems? Thanks guys. (BTW i drive a 99 coupe)
-aaron
-aaron
spoon mirrors
vision still good although stock is better * i got a set*
replica spoon mirrors sucks looks is there vision
my boys got a set anyone who wants it Make an offer brand new for TEG.94-95
vision still good although stock is better * i got a set*replica spoon mirrors sucks looks is there vision
Vision Mirrors dont offer much Vision
Well, I was going to get the normal JDM non-power folding mirrors, but everone says the visibility gets cut in half......so all you have to do is switch the actual mirror-glass? thanks
-aaron
-aaron
-aaron
The mirrors fit USDM cars fine. Visibility is reduced a little bit due to the smaller size. No cutting what-so-ever. No wiring problems because they're not power.
-aaron
You can get the replica ones it's POWER hehe
The issue with the visibility ia that the mirrors are designed for the driver to be sitting on the right hand side. Therefore the left hand mirror is designed to tilt a certian way, while the right hand mirror is also designed to tilt a certian way. This is to allow someone sitting in the right hand seat the best visibility. When you try to adjust the mirrors to left hand seat spec they won't quite tilt they way they need to. You just have to get used to it.
[Modified by merritr, 10:36 PM 10/8/2002]
i have the spoon mirrors and it took awhile to get used to.......but, without a doubt try some of those Broadway mirrors for your rearview mirror. it may help a little.
rex03
Oct 19, 2003 05:10 AM
