Need help asap,
Old Dec 20, 2011 | 11:20 PM
Ek_Eli's Avatar
Default Need help asap,
Hey whats up guys
I have a 16x7 +43 wheel , I want them to sit flush to my fender
what size spacer should I use ?
btw I drive an ek hatch if that helps
thank you ,
Old Dec 21, 2011 | 04:56 AM
toyomatt84's Avatar
Sanji
Default Re: Need help asap,
Well, you're in a bit of a dilemma with that size wheel. It all depends on if the wheel has reliefs next to the standard lug holes on the backside of the wheel's hub (gaps between the lug holes, if you will). If it does have clearance there, your original lug studs will be able to clear the wheel with some studded spacers. If not, you'll need to get extended lug studs and run some standard wheel spacers. Ideally, you'd be looking at a 10 to 15mm spacer, both of which are too large for the factory lug studs.
Old Dec 21, 2011 | 05:45 AM
ssmtyper's Avatar
EJ2B16
Nov 25, 2011 09:05 AM
93grayeg
May 12, 2011 09:37 AM
1slowcrx
Mar 2, 2010 11:16 PM
nsxtasy
Feb 6, 2006 03:47 PM
mingbling
Jul 27, 2004 09:05 PM
