F22a2 won't fire, tried new dizzy, main relay clicking fine
Old Dec 20, 2011 | 03:32 PM
deraj1986's Avatar
Default F22a2 won't fire, tried new dizzy, main relay clicking fine
It was running last night perfect. Went to start it for work and it cranks with no fire. Put on new distributor after work and no luck.
Timeing belt is new as well
Old Dec 21, 2011 | 06:06 AM
brian1990's Avatar
Default Re: F22a2 won't fire, tried new dizzy, main relay clicking fine
Are you getting fuel try to see if ur fuel pump is workin
Old Dec 21, 2011 | 12:29 PM
PT-Tuner.com's Avatar
Try spraying some starting fluid/ether in the intake and crank, if it starts and dies, its a fuel issue.
Old Aug 24, 2012 | 11:30 AM
deraj1986's Avatar
i had the wrong dizzy, they changed a little sometime between 1990 93. thanks anyway
88LsRex
May 29, 2012 03:41 PM
slvlile
Oct 5, 2010 09:58 PM
indianbullet
May 14, 2009 07:56 AM
Niskyspy
May 9, 2008 09:41 AM
LilMissCrystal81
Nov 19, 2004 11:26 AM
