Clunking Drum Brake
Old Dec 20, 2011 | 02:35 PM
Dundravidian's Avatar
Default Clunking Drum Brake
Hey guys! New guy here
I have a 2001 Honda Accord 2.3L AT. Its got 184k (kms). I've recently got it used, few weeks ago. Last couple days I was testing out the ABS as it snowed about half a cm. After a few hard stops ABS works, but I've noticed a clunking noise coming from my rear passenger side brake now. It only happens when I apply the brakes slightly while going at a very low speed. What could be the problem?
Some insight or suggestions would be appreciated thanks!
Old Dec 21, 2011 | 04:31 PM
Default Re: Clunking Drum Brake
I should also add that when I brake harder the noise goes away. There is a similar thread about the exact issue I'm having.
https://honda-tech.com/forums/showth...brake+clunking
In short check the stabilizer links to see if its loose, make sure the bar is tightened properly to the link. I haven't had the time to check it out, for now I avoid the noise by braking late.
Old Apr 23, 2012 | 04:49 AM
SLATER97EX's Avatar
I know this is an older thread but did this fix your issue? I'm having the same problem after I just replaced ALL my rear brake components. Thanks!!
Old Apr 30, 2012 | 01:36 PM
Yes I did resolve this issue...it was not as bad as suspected. Took it to my mechanic he opened up the drum brake cleaned it with an air compressor to remove any dirt and that was it, I've never had that problem again.
It could possibly be the same for yours if you didn't clean your brakes before replacing the components. I'm not for certain
GAngulo7
Honda Civic (2001 - 2005)
Jan 26, 2010 08:17 PM
20x52eq1040
Jan 13, 2008 05:16 PM
Lissav
18
Jul 30, 2006 03:00 PM
