Low dyno #'s, k24/k20 mild build
Old Dec 20, 2011 | 09:50 AM
type_r_teggy's Avatar
Default Low dyno #'s, k24/k20 mild build
posting for a friend,
car after a road tune just went on the dyno for a base pull...
226whp and 17xlb/ft
few parts are,
head
stock ITR head
stock type r cams
skunk retainers
skunk 2 pro manifold and TB
RC 780cc injectors
OBX fuel rail
3inch intake with k&n
OBX "race" headers
custom slightly bented 3inch exhaust
Block
darton sleeved K24 89mm
CP 11.2CR pistons
balanced crank
kpro
i know its on d stock cams but i really expected more
is it the tune or what?
or that figure is ok with you guys?
i would try to get dyno graph
Old Dec 20, 2011 | 09:54 AM
Default Re: Low dyno #'s, k24/k20 mild build
the tuner says it needs biggers cams to make any power
Old Dec 22, 2011 | 08:50 AM
klzemx6's Avatar
i'm sure the obx header is robbing a huge amount of power
Old Dec 22, 2011 | 09:07 AM
pgpbubble's Avatar
and your intake manifold.
Old Dec 22, 2011 | 01:40 PM
but its ah skunk 2 pro wid tb. i dunno
Old Jan 2, 2012 | 01:11 PM
t.schultz's Avatar
So it was road tuned, then just put on a dyno for one pull? Or did they do more pulls to try and tune it out?
Old Jan 2, 2012 | 03:37 PM
egvera89's Avatar
the compression on the motor is like a stock k series so since you also have stock cams you cant really make too much more. maybe 235 on 93 octane. get bigger cams and run better header and you will see a nice increase in whp.
Old Feb 15, 2012 | 02:21 PM
CHEETAH's Avatar
Doesn't sounds too bad, although the torque i would have expected closer to 200. Also, how much total ign adv and how much VTC advance? using the factory ITR VTC gear? need to know all that to help. And like someone asked, did they try to tune or jsut did one or two passes on the dyno.
tuning for a/f is just one part of tuning, you need to find the optimum VTC and ign timing too.
Old Feb 15, 2012 | 03:27 PM
Deetz's Avatar
Crazy Honda Guy
The type r cams you are running are not all that aggressive, it would be worth looking into upgrading them
Old Feb 21, 2012 | 08:49 AM
kteggy88's Avatar
Mine made about 270 with Rods and specd pistons. But it was a great tuner!
Old Feb 24, 2012 | 10:55 PM
civic20's Avatar
My friends make 244 with k24 block with stock bottom end with z3 head. DC header, tsx TB and cams. So it could be the tune. Also obx header is a big red flag.
Old Feb 26, 2012 | 04:42 AM
Garrett's Avatar
those cams aren't not designed to make great power for k24 engine
the header need to be change too
TurboTegB18c
54
May 24, 2007 05:53 PM
wildoutwhitegsr
21
Nov 19, 2006 10:24 PM
dnrprojectsvp
52
Jul 25, 2006 11:22 AM
tnsxsear1
Feb 2, 2005 11:08 AM
TurBoTeG
Apr 21, 2004 01:33 AM
