need help!!!
Old Dec 20, 2011 | 09:25 AM
jdmhatch559's Avatar
Default need help!!!
So my buddy has a 91 accord and is having problems with it. He says it jerks when you accelerate and sometimes it wont speed up fast it'll whine while it accelerates. And when the engine light comes up he says it runs fine.. any thoughts? Please help.
Old Dec 20, 2011 | 11:19 AM
GhostAccord's Avatar
Default Re: need help!!!
When the check engine light comes on retrieve the stored codes from the ECU. There is a self diagnosis procedure that can be done very easily. All it requires is a paper clip to short the SCS connector.
If you search for self diagnostic procedure or paper clip trick. I'm sure you will find a number of How-to threads.
Old Dec 20, 2011 | 12:59 PM
PT-Tuner.com's Avatar
When the CEL comes on, your "buddy" should take a paperclip and jump the service connector in the passenger side kickpanel. Count the flashes, long flashes are 10, short flashes are 1, long pauses are breaks between codes, once the "list" of codes is done, they will repeat.
My best guess as to what the issue is? Probably EGR or Oxygen sensor. You can check if its the o2 sensor causing it by simply unplugging it, if it runs great, replace the o2 sensor.
aging-accord
Jul 21, 2007 09:20 PM
nguyennhatquang
Nov 16, 2005 02:32 AM
Frankie324
Jul 14, 2004 07:48 PM
sCeRaXn
Aug 1, 2002 02:40 PM
