91 EF short i guess...HELP
Old Dec 19, 2011 | 04:23 PM
Beasting EF22's Avatar
Icon2 91 EF short i guess...HELP
Alright so in my 91 ef hatch **** just stopped working.
Fresh rebuild from the ground up everything is brand ****ing new. (everything!)
Car ran great for 2 weeks during the breaking in process. So Sunday night i start my car up to pull in garage.
Out of nowhere my corner lights go out and also my in dash light. First off i thought oh no big deal just a fuse.
check over all fuses all good. replaced all of them just to make sure.
Still have no in dash light, running light nor headlights. Also fuel pump is not priming. That lead me to believe that is was the main relay.
Just got threw putting in new relay and still nothing.
My relay is not clicking at all, and all of the above are still not working.
Any ideas? please help me out this car is fresh and i would hate to sell it but im to the point im done with it. Its always something wrong
just my luck i guess.
Old Dec 20, 2011 | 06:16 AM
Default Re: 91 EF short i guess...HELP
help
Old Dec 20, 2011 | 06:49 AM
zrickety's Avatar
Does it have a wire tuck?
Old Dec 20, 2011 | 06:50 AM
no sir
Old Dec 20, 2011 | 07:04 AM
zrickety's Avatar
If you have a multimeter...
Edit- actually it sounds like a loss of power, which should be easier to find. Turn the key on and check for voltage at the underhood fuses, and dash fuses. You have a bad connection or something loose.
Old Dec 20, 2011 | 07:49 AM
have checked the fuses but i will do it once again when i get off work.
I was thinking it was the main relay since my fuel pump is not priming. forgot to mention normally my check engine light goes off after fuel pump primes.
well i hear no clicks from the main relay and my check engine light is staying on.
Car just cranks and cranks.
Old Dec 20, 2011 | 08:27 AM
FSRslug's Avatar
What's the code?
Old Dec 20, 2011 | 08:35 AM
there is no code i wish there was one then i could figure it out.
Old Dec 20, 2011 | 09:39 AM
FSRslug's Avatar
Your CEL is on, but there is no code? Are you OBD0? A solid light is a code 0. Check all the plugs at the ECU and make sure they are seated properly.
Old Dec 20, 2011 | 10:03 AM
yeah im obd0, i have unplugged and plugged them back in time and time again.
i dont get why just my indash lights, headlights, and fuel pump wouldnt be working
starting to think someone messed with my ****.
Old Dec 20, 2011 | 10:26 AM
10psiLsEf2's Avatar
sounds like a dead ignition switch.
get in your car
put key in ignition
turn it all the way forward with out clutch engaged.
and mess with it back and fourth THE SLIGHTEST BIT is what you wana do!
this has happened to me and i did this. and bam my lights turned on.
;good luck. keep us posted
Old Dec 20, 2011 | 10:31 AM
Appericate the input. but if the ignition switch was dead wouldnt my car not crank ?
Old Dec 20, 2011 | 10:35 AM
Ignition switch symptoms are:
The dash will go dark when it dies (no warning lights, no shift indicator, no electrical).
Car stalls then can be started, then stalls after driving or idling for a few seconds or minutes.
Car runs fine when the key slightly held at start position or part way between start and ON position. In rare cases, this symptom is similar to a bad main relay.
Ignition (electrical) switch is hot.
i have hazard which they call warning lights ? ill try it anyways as soon as i get off work.
Old Dec 20, 2011 | 10:38 AM
10psiLsEf2's Avatar
my car still cranked but would ignite and if it did it would die soon as key was moved.
check grounds
tranny ground
thermostat ground.
also check the 2 wires going into your fuse box in the engine bay (2 philips heads)
Old Dec 20, 2011 | 11:08 AM
All grounds i discounted wire brushed and re connected all good.
the two wires in the fuse box are connected good as well.
if the inginton switch is bad would that not allow my fuel pump to turn on ? please
tell me yeah hahah
Old Dec 20, 2011 | 11:13 AM
10psiLsEf2's Avatar
ignition controls power throughout the vehicle!
Im not a great electrical guy! but theres some guy on here thats a genius!
think his user name is FCM
Old Dec 20, 2011 | 11:36 AM
well i hope that he reads this and is able to help me out.
but i get off at 5 30 and I'm going to try this key thing you told me.
If that doesn't work should i buy a new ignition switch ??
Old Dec 20, 2011 | 01:25 PM
10psiLsEf2's Avatar
NEVER jump to conclusions untill you have properly diagnosed the issue!
Send him a pm. i guess
Old Dec 20, 2011 | 01:42 PM
yeah i know what you mean...
i tried the key thing that worked with yours and with my luck that didnt work.
Any other ideas ??
Thanks for everyone's input and trying to help me out.
Old Dec 20, 2011 | 01:49 PM
10psiLsEf2's Avatar
check the underhood fuse box. could be one of those big fuses.
Old Dec 20, 2011 | 01:52 PM
checked them just now all look to be good.
I have never been stomped by my own car like this. normally i figure it out
i hate this ****.
Old Dec 20, 2011 | 01:56 PM
10psiLsEf2's Avatar
wait you said you started the car, then the lights turned off?
Old Dec 20, 2011 | 02:07 PM
yeah man i started the car up and i turned on my corner light because that is what my
oil pressure light is hooked up to, and when i pulled in it the garage my in dash lights went out and my corner lights.
although my brake lights and turn signals were still working i shut the car off
to check the fuses. all the fuses were good but i replaced them to make sure.
i can tell you my main relay is not clicking at all when i put the key in and it is brand new bought it last night.
Old Dec 20, 2011 | 03:20 PM
10psiLsEf2's Avatar
are you getting power to the outside fuses?
did anything smoke at all?
Old Dec 20, 2011 | 03:31 PM
no smoke, no pop, no burned wires.
With my test light i have power to to fuse box in the bay.
