obd0 to mpfi obd1 parts?
A fellow member gave me his 2 cents about converting to obd1 in stead of just doing the mpfi from the si but cant seem to find exactly what parts i need because tgeres plenty of obd1 parts in the local junkyard. parts list would be appreciated
First go from DPFI to MPFI.
You can search that on your own... so many write ups.
However, you won't need the ECU nor the distributor if you plan to go directly to OBD1.
OBD1 will require a conversion/jumper harness (you could make this on your own, but it's far easier to just buy it)
4 wire O2 sensor
OBD1 distributor
4 wire O2
OBD1 fuel injectors are optional (no resistor box needed as in the typical MPFI conversion)
4 wire O2 sensor
OBD1 distributor
4 wire O2
hi-Powered
Apr 30, 2005 01:28 PM
EFing8
11
Dec 15, 2002 09:08 AM
