What's the problem with fan speed switch light not working...
Planning on removing dash tomorrow to try and repair the speedometer with a replacement circuit board. Noticed the fan speed switch does not light at night but the temp switch does. What may the problem.......does it have a separate bulb and maybe a fiber optic line has fallen loose.......not sure what to look for .......any heads up.....
Pulled the dash bezel out today and found the two switches and push button air functions unit one peice. On the back, right in the middle of the temp and speed switches , was a small bulb. I changed it out......but not sure it was bad......because I had light at the temp switch. Will check it and see if I made any improvement asap......
Bertsch911
11
Dec 24, 2019 06:01 AM
johnwohl
Dec 17, 2008 09:44 PM
tennisnut
Jan 19, 2007 11:32 PM
