Suspension & Brakes Theory, alignment, spring rates....
90-91 civic megan racing springs experience?
Old Dec 18, 2011 | 02:55 PM
xlusiveracer's Avatar
Default 90-91 civic megan racing springs experience?
i bought some megan racing springs for my 90 civic.i put them on and the front sit kinda low like half a finger and the rear is like 3 fingers a lil lower than stock.its like a slant and you can tell it is.i was wondering if anybody else bought this and had the same result thanks.
Old Dec 18, 2011 | 03:22 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 90-91 civic megan racing springs experience?
You sure you have them on correctly and not reversed?
Old Dec 18, 2011 | 03:27 PM
what you mean reversed as in the fronts are backs or the fronts are upside down?
Old Dec 18, 2011 | 03:28 PM
there sittin on toikco blues by the way.how are the springs suppose to be up right?the flat side should be on bottom right?
Old Dec 18, 2011 | 03:43 PM
The Grumpiest
It sounds like you have the fronts in the rear. BTW. anything Megan is crap.
Old Dec 18, 2011 | 03:47 PM
well i had them switched before and the front would be higher than the rears.you think its the springs itself then?
Old Dec 18, 2011 | 03:51 PM
The Grumpiest
I told. you. Megan is crap. And this is the risk you run when you only run with lowering springs. You will NEVER get your ride height the way you want.
95LSv
Suspension & Brakes
May 11, 2010 09:12 AM
