New with question
Old Dec 17, 2011 | 06:42 PM
custommachine's Avatar
Default New with question
I have a 94 honda accord with a problem. I replaced both cv joints and the right front wheel bearing. The bearings keep going out. I am on my third change in the last 6 months. Is it possible that the new cv joint is causing the problem? I thought that perhaps it is too long and causing pressure on the bearing? Any help would be great here I am just about ready to junk the car.
Old Dec 17, 2011 | 07:16 PM
nus_dogg's Avatar
Default Re: New with question
Did you torque or impact the axle nut on? I've learned that, do not impact the axle nut on because that's your bearing pre-load. I would try to torque the nut on instead this time to see if it'll fix it. But I've always impact mine with no problem. Otherwise, it's installer error.
safedriver
Jun 23, 2014 02:39 PM
L2ILL
Oct 22, 2012 01:38 PM
cdturbo
Jun 16, 2011 10:51 PM
93ex2draccord
Nov 30, 2005 11:36 AM
90babyblue
Jun 20, 2004 04:27 PM
