b18b1vacuum diagram for 88 crx
Old Dec 17, 2011 | 05:51 PM
viking-101's Avatar
Default b18b1vacuum diagram for 88 crx
I've been looking everywhere on the web and so far i come up with different vacuum diagrams for my 88 crx. Does anybody have a dull diagram on a b18b1 or has anybody done a b18b1 swap in a crx and could tell me what all you did?
Old Dec 17, 2011 | 06:21 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: b18b1vacuum diagram for 88 crx
What is your problem exactly? It all depends on what OBD you are as to what you need to hook up. So without proper information it's impossible to help you; I can assUme all day, but that's a waste of everybody's time.
Old Dec 17, 2011 | 06:28 PM
viking-101's Avatar
Sorry abou that for not giving out alot of into. My motor is a obdo b18b1 with b18a1 trans. I've been looking for a vacuum diagram to hook up everything on the throttlebody, intake, purge solonoid, charcoal canister, etc.
1739gvr4's Avatar
this what you looking for?
Old Dec 17, 2011 | 06:45 PM
viking-101's Avatar
So would anybody know what the valve is that sits right under the throttle body and intake would be and what it connects to?
Old Dec 18, 2011 | 04:52 AM
DO IT ON ALL FOURS
Those are coolant lines and NOT vacuum lines...
Old Jan 2, 2012 | 10:42 PM
viking-101's Avatar
Went to the salvage yard today a pulled the pressure regulator cut off valve and purge cut off solenoid. On the bottom of both solenoids they have a y-shaped adapter which converts it into on hose, and 1 hose coming from both sides of the solenoid. i know for sure that on the bottom that has the y-shaped adapter to it plugs into the back of the im but what about the hoses coming from each solenoid. Could i add another y-shaped adapter piece to it to convert it into 1 hose and plug it into the charcoal canister or would i have to get another solenoid?
Old Jan 8, 2012 | 02:46 PM
viking-101's Avatar
Hows this? I used a y adapeter to tap into the hoses and pluged them into the charcoal canister and the ones for the bottom i used to put into the back of the intake manifold.
Black Maverick
Jun 14, 2007 04:10 AM
goatboy69
May 10, 2006 10:55 PM
UNDER PRESSURE
Apr 29, 2003 08:25 PM
