clutch damper
Old Dec 16, 2011 | 07:53 AM
bdmlilburn's Avatar
Default clutch damper
has anyone had experience with this thing being removed for a long period of time? i was considering removing mine to clean up the area a bit and lessen the possibilities of air being trapped in the system(my clutch pedal is being lazy).
i have heard it is there to put less strain on the clutch and i have heard it is there just for comfort. Over an extended amount of time will its removal cause any extra wear on the clutch system?
Old Dec 16, 2011 | 02:26 PM
nus_dogg's Avatar
Default Re: clutch damper
You're right about comfort and smooth engagement. It's fine to remove if you want.
Old Dec 16, 2011 | 04:49 PM
bdmlilburn's Avatar
cool i may in the future. found out my problem though. still air in the lines. turns out the bleeder was leaking air while one man bleeding. decided to bust into some unused parts and found a pair of brake bleeders with the check valves
1x m8x1.25 check valve bleeder and now bleeding the clutch is a walk in the park
Old Dec 16, 2011 | 07:16 PM
nus_dogg's Avatar
Haha, nice. Or you could've gravity bleed the system, but that'll take days. Lol.
Mario Locatelli
Feb 7, 2014 11:36 PM
Keith_B
Jan 26, 2009 07:20 PM
93SiHB
Oct 2, 2005 10:00 AM
Perfourmance
Nov 16, 2004 11:08 AM
DSGB.
Mar 19, 2003 02:40 PM
