gsr not turning over or doing anything
Old Dec 15, 2011 | 11:24 PM
momodc221's Avatar
Icon6 gsr not turning over or doing anything
my gsr is not turning over or anything. yesterday everything was working fine. i go out to start it up nothing no clicking or anything. charged the battery cables r all good. tried to jump start it nothing. i think it might b the ecu. any suggestions?
Old Dec 15, 2011 | 11:52 PM
DirtyDA9's Avatar
Default Re: gsr not turning over or doing anything
Check grounds. Is your cel light on with the key in the on position? If it's the ecu then the cel will stay on.
Old Dec 16, 2011 | 01:35 AM
momodc221's Avatar
what do u me by cel lights like the battery, check engine, oil lights? if so yes when i turn the key they stay bright like nothing happen.
Old Dec 16, 2011 | 02:00 AM
mouab18c1's Avatar
No click? Sounds like a dead starter. Or check your starter ground wire.
Old Dec 16, 2011 | 08:20 AM
bnetkillzone's Avatar
So im assuming your CEL is on?
Check for codes here: https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
Get back to us and tell us whats its throwing.
Old Dec 16, 2011 | 09:37 AM
momodc221's Avatar
nothing like that. thats wht i check first.
Old Dec 16, 2011 | 09:38 AM
momodc221's Avatar
Check for codes here: https://honda-tech.com/forums/showthread.php?t=978933
were can i get an obd1 code reader cant find one.
Old Dec 16, 2011 | 09:49 AM
mouab18c1's Avatar
Follow the Diy. You dont need a code reader
Old Dec 16, 2011 | 12:01 PM
DirtyDA9's Avatar
Cel means check engine light. If it stays on when the key is in the on position that means either main relay or ECU is bad, but with the problems you are having, it would be the ecu. Go to the link above explaining how to retrieve codes. If the cel light doesn't stay on, check codes anyway, but from how you are describing it I would say starter ground/relay/solenoid.
Old Dec 16, 2011 | 06:13 PM
hk_gsrguy's Avatar
Rubber gromet for neutral safety switch
Old Dec 16, 2011 | 06:17 PM
DirtyDA9's Avatar
It's not the rubber gromet that goes bad, it's the actual plastic clip that the button contacts
Old Dec 16, 2011 | 06:31 PM
momodc221's Avatar
ok thanks for tht link i will try it tomorrow n let u knw thanks alot.
Old Dec 17, 2011 | 12:26 PM
momodc221's Avatar
i checked it in this is wht i got 6 fast blinks it says it the ect so now i need to get these switches.
Old Dec 17, 2011 | 03:41 PM
hondalike's Avatar
ECT isn't going to stop your car from turning over though. As mentioned check around by your pedals to see if there's any little white plastic pieces from the clutch interlock switch.
You can also check for voltage at the starter S terminal (the little one with the boot on it). Start as normal and have someone put a meter on that terminal as the key is turned. The interlock sends ground to the cut relay so no juice if it's broke. Look for the plastic pieces.
Or just look up to see if it's busted on the end.
Old Dec 17, 2011 | 03:48 PM
DirtyDA9's Avatar
What he said^^. And to check for a bad ect, when you do get the engine to crank if it doesn't start still, unplug the ect and if it starts the, it is a faulty ect. But that is not what's causing the no cranking condition.
Old Dec 18, 2011 | 08:00 AM
momodc221's Avatar
ok were is the clutch interlock switch located at. i dnt see any litter white plastic pieces by the pedal.
Old Dec 18, 2011 | 09:19 AM
DirtyDA9's Avatar
It's called a nuetral safety or clutch safety switch. Just follow the clutch pedal up, and you will see a button style thing that the clutch pressed every time the clutch pedal is depressed (not pressed). Google search integra clutch safety switch, there are plenty of images I'm sure.
Old Dec 18, 2011 | 12:08 PM
seanbev24's Avatar
Once you know the battery is fine, the first test for a no crank should be done at the starter with a multimeter. If you don't have one and you want to do any work on your car, get one even if it's a cheap *** Harbor Freight meter.
Test for battery voltage at the big starter terminal. If you have over 12v...
Unplug the small wire to the starter and put your red lead to the harness side. Hold the black lead to ground. When someone pushes the clutch and turns the key, do you get battery voltage on that wire?
If so, you have just proved that EVERYTHING else in the starting circuit works in less than a minute, so the starter is bad. That's the key to diagnosing electrical: What is the easiest and fastest way to prove which part of the circuit isn't working.
If you don't get voltage there, it's most likely the clutch switch or ignition switch. Now is the time to start troubleshooting the rest of the circuit.
Old Dec 18, 2011 | 02:27 PM
hondalike's Avatar
Check your #39 ignition switch fuse in the underhood fuse box while your at it.
Old Dec 18, 2011 | 02:32 PM
10psiLsEf2's Avatar
also check your ecu fuse. located under the hood in the fuse box.
Old Dec 18, 2011 | 07:35 PM
momodc221's Avatar
its the one one the very top right. not the one closest to the pedal. been tryn to find were i can get one from.
Old Dec 18, 2011 | 07:37 PM
momodc221's Avatar
gonna get one of those never thought i would need but goes to show u it can happen anytime.
Old Dec 18, 2011 | 07:40 PM
momodc221's Avatar
Old Dec 18, 2011 | 07:42 PM
momodc221's Avatar
i hope its not tht starter i just had tht replace a lil while ago but never hurts to check again
Old Dec 18, 2011 | 07:50 PM
DirtyDA9's Avatar
Well it could be a crappy starter or the person installing did a shotty job...
