Flywheel Issue!!
Old Dec 15, 2011 | 06:44 PM
88LsRex's Avatar
Default Flywheel Issue!!
Im swapping a d16y7 into my crx, im keeping the flywheel and clutch on it.
so will my starter from the d16a6 work? (threw a rod)
I know the Y7's flywheel is a little bit bigger.
Old Dec 15, 2011 | 06:54 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Flywheel Issue!!
No, it's not.
Let me clarify...
http://www.d-series.org/forums/trans...ro-clutch.html
Old Dec 15, 2011 | 07:24 PM
88LsRex's Avatar
So I cant use the y7 PP/Clutch/Flywheel with a 91 si trans.
Old Dec 15, 2011 | 07:36 PM
turbostd's Avatar
you can use the y7 clutch/pp/fw as long as the trans you use is not an 88
Old Dec 15, 2011 | 07:37 PM
10psiLsEf2's Avatar
this ^ or a 4 speed i think!
Old Dec 15, 2011 | 07:45 PM
88LsRex's Avatar
my trans is a 91' Si trans....what starter do i use?
Old Dec 15, 2011 | 07:47 PM
10psiLsEf2's Avatar
any sohc starter will work. be it obd-0 obd-1 obd2. its just 2 wires.
i might be wrong but!
b series starters are all compatable. unless you have a itr flywheel then u need a different starter.
Old Dec 15, 2011 | 07:51 PM
88LsRex's Avatar
i was going to use a A6 distributor
and a alternator,starter ef civic or hatch (obd0)
Old Dec 15, 2011 | 07:53 PM
10psiLsEf2's Avatar
yea it should work.
Old Dec 16, 2011 | 05:11 AM
TeamRedline89Hatch's Avatar
My obd 0 LS starter works just fine with my ITR flywheel.
Old Dec 16, 2011 | 06:55 AM
thejdmjew311's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/stock-clutch-fitment-guide-2284956/
maybe this will help?
Old Dec 16, 2011 | 07:53 AM
10psiLsEf2's Avatar
I HEARED there is 2 different starters for b series.???
Im speaking about brands that came from factory. 1 of them doesnt work with itr flywheel!
acmoc
25
Dec 9, 2011 09:03 PM
hatchet_honda
13
Nov 6, 2010 12:15 PM
JScott3d
Apr 17, 2009 09:26 PM
darkracer
Apr 27, 2003 04:38 AM
apexii
Feb 19, 2002 12:57 PM
