p30 pistons with stage 3 cams clearance???
Old Dec 15, 2011 | 08:41 AM
94EG2B18's Avatar
Default p30 pistons with stage 3 cams clearance???
So I'm building a gsr block with ITR crank and b16 head..... I've searched for hours and found no definite answer. Will Nippon p30 pistons have piston to valve clearance issues with skunk2 tuner stage 3 cams? And also the Zeal compression calculator says my the ratio will be around 11.3 to1. But the site that sells them says 12.1 to 1... what's the known ratio for this setup if anyone here has had it? Any input is appreciated....
Old Dec 15, 2011 | 11:29 AM
94EG2B18's Avatar
Default Re: p30 pistons with stage 3 cams clearance???
ttt anybody? Or should i just go with pr3 pistons to stay on the safe side? i would hate to find out later that I could have gone with p30 without a problem....
Old Dec 15, 2011 | 01:50 PM
94EG2B18's Avatar
Bump! anyone? I'm ready to order pistons just want to know which are better for my setup
Old Dec 15, 2011 | 04:17 PM
94EG2B18's Avatar
Where the experts at???
Old Dec 15, 2011 | 04:53 PM
Jdubbs6101's Avatar
Lol only way to be sure is to check your p2v clearance. There are a few write ups on this site that will tell you how to check. It's a little time consuming but well worth the time also while you are checking on p2v look up how to degree your cams.
Old Dec 15, 2011 | 05:07 PM
Texas4door's Avatar
I'm gonna bet that if there's no reliable info out there, that means it either didn't work and someone is too embarrassed to fess up about their busted motor, or the numbers have been run and it won't work.
It's tough to be a pioneer sometimes
*shrug*
Old Dec 15, 2011 | 05:53 PM
94EG2B18's Avatar
Yea... moneywise I'm not in a good position to be a pioneer... so I'm just gonna play it safe and go with the pr3 pistons and maybe a thinner headgasket.... I'm trying to get a high 11 to 1 compression. Plus with the huge stage 3 cams more than likely I would've had clearance problems. Are thinner headgaskets a good idea? Or are they less durable because they are thinner?
Old Dec 15, 2011 | 09:31 PM
Texas4door's Avatar
Well, a thinner head gasket is gonna give you higher compression for sure.
I don't think they're less durable, but don't quote me on that one.
If you HAVE to have higher compression by having the head closer to the block, have the head milled, that way you don't risk popping a thinner head gasket.
There's a few compression calculators you can use that'll give ya an estimate as to your future compression ratio with head milling and all that taken into consideration, but remember that each motor is a little different (and I think you already found the Zeal calculator anyways...*looks up* yep, you did ^^;; )
Well, I entered the shaved head amount of .025 in and it gives exactly 12.1 : 1 compression...so there ya go!
kart_driver
26
Aug 31, 2010 01:07 PM
804tuned
Feb 6, 2010 10:30 PM
joethejoeman
Feb 7, 2007 01:42 PM
1BadDC2
Dec 1, 2003 05:25 PM
