starting problem 91 ed6
Old Dec 15, 2011 | 04:11 AM
fredefhatch's Avatar
Default starting problem 91 ed6
hi guys i have a 91 ed6 hatchback well first it started as the clutch not working properly fixed it it was the regulator then to start the car u have to push the clutch in all the way as hard as u can and get lucky if the scar starts any ideas?
Old Dec 15, 2011 | 04:53 AM
90civic-ZC's Avatar
Default Re: starting problem 91 ed6
Does the clutch engage like it should? On my hatch I dont need to press in the clutch to start. Does your main relay click when you have the ignition in the second position? Hearing the click and Fuel pump when the CEL comes on and off. Can you give us a little better of a discription on what happens and what you do when you try to start the car versus when it starts.
Old Dec 15, 2011 | 05:14 AM
crvtectim's Avatar
What's a clutch regulator???
Old Dec 15, 2011 | 05:17 AM
well i hear the fuel pump i have had main relay problems before and i know for sure its not that everything engages my dad said something about a switch that goes on when u press the clutch that lets the car turn on any input?
Old Dec 15, 2011 | 05:22 AM
where the clutch cable is close to the transmission theres a nut that regulates the clutch i guess
Old Dec 15, 2011 | 06:07 AM
thejdmjew311's Avatar
yeah the switch that closes when your foot on the clutch allows power to the ignition switch. Mine's bypassed like 90civic-ZC's is. That could be bad on your's.
Old Dec 15, 2011 | 06:15 AM
yeah the switch that closes when your foot on the clutch allows power to the ignition switch. Mine's bypassed like 90civic-ZC's is. That could be bad on your car.
Old Dec 15, 2011 | 06:59 AM
90civic-ZC's Avatar
Yeah I know what you're refering to but since I dont have it I cant speak on any experience of having it go bad. Is it a sensor of some sort? and did you also replace that part with the clutch or were you trying to say that it could be a problem?
Old Dec 15, 2011 | 07:07 AM
Are you talking to me?
Old Dec 15, 2011 | 07:27 AM
90civic-ZC's Avatar
No, the op....
Old Dec 15, 2011 | 02:23 PM
all i had to do was regulate it back basicly tighten it because it was lose and do u have any info on how to bypass it and where exactly is it located>?
Old Dec 15, 2011 | 03:23 PM
lazy14's Avatar
jus trace the wires, then jump them, but be careful when u start ur car then, cuz it will start in gear
Old Dec 16, 2011 | 06:51 PM
so i fixed the starting problem but after all these problems dealing with the clutch my clutch finally died at 132,500 miles so time for a new clutch
Old Dec 17, 2011 | 04:40 AM
crvtectim's Avatar
Glad you got it running. Btw, the clutch switch is often referred to as the neutral safety switch. Now, before you go snatching the trans out for a new clutch, try adjusting the clutch cable again. Since you tightened it up, there's a good chance you got it too tight which would not allow your pressure plate to clamp down on the clutch with all its might, thus causing the clutch to slip. Try to loosen the cable up until you have about an 1/8" of space between the throwout bearing and pressure plate. If the clutch still slips after that, replace it.
dannysolis92005
Apr 6, 2011 04:32 PM
Nataku
Oct 19, 2007 11:39 AM
Honduh Uhcord
Oct 14, 2007 02:33 PM
Duff Beer Man
Jul 11, 2006 12:57 AM
rough_draft
Feb 8, 2005 04:24 PM
