ek9 or ek3 hachback - Which is better for K20A swap and the track?
Old Dec 15, 2011 | 03:08 AM
fishpimp's Avatar
Default ek9 or ek3 hachback - Which is better for K20A swap and the track?
hi,
im about to start a project.Its gonna be a k swap and im using it for tracks.Is it better to get a ek9 chasis or a ek3 chasis to start with.Im tesed both and the ek9 seems to be better than ek3 but what makes the ek9 so stiff and stable compared to the ek3.This is the first step and its the most crucial part.I want a car than can track than a straight line hero.Balance is important.Is it true that the k20a is much heavier than the b16b in total weight.Can anyone shed some light?thanks
Old Dec 15, 2011 | 03:23 AM
Turpid Porpoise's Avatar
Default Re: ek9 or ek3 hachback
Originally Posted by fishpimp
hi,
Its personal preference. Both models can be made to do just about the same thing. Do you have a k swap? If not do you understand how much it costs to do one?
Old Dec 15, 2011 | 05:21 AM
kaiba's Avatar
EK9 = Type R chassis
Old Dec 15, 2011 | 06:02 AM
Deetz's Avatar
Crazy Honda Guy
As mentioned above, the EK9 is a civic type R, this is what you tried out??
Also, the K20 engine i believe weights less than a B18
Old Dec 15, 2011 | 06:11 AM
Its not heavy, I just loaded one into my truck the other night and it really wasnt bad.
Old Dec 15, 2011 | 08:24 AM
Arthas's Avatar
Default Re: ek9 or ek3 hachback - Which is better for K20A swap and the track?
Do you know what you are talking about.
Old Dec 15, 2011 | 08:27 AM
98civdx's Avatar
Master Detailer
I was able to dig up a little info on the weights. It seems the K20 "fully dressed" weighs about 212lb's
Where i was only able to find a short block weight of 102 for the short block, and 90 for the trans. For B series.
Pretty suprised to see that.
Op, being as the car is going to be raced, and likely wont have much for stock parts left on it, why does it matter?
The EK9 may have quite a few differences, but I highly doubt it will be a night and day difference.
Old Dec 15, 2011 | 10:01 AM
Me or the OP? I assumed he was just talking about the hatch or coupe since the real ek9 is not really an option.
Old Dec 15, 2011 | 12:08 PM
98civdx's Avatar
Master Detailer
Why would it not be a option?
We don't know where he lives.
Old Dec 15, 2011 | 02:44 PM
I guess your right, I just hope he doesn't want to ruin a real CTR with a K motor. Not that it wouldn't be quick it just wouldn't be right IMO
Old Dec 15, 2011 | 02:53 PM
98civdx's Avatar
Master Detailer
It comes down to personal opinon I guess.
I've only seen a handful of CTR's in person, and 2 had k swaps.
Old Dec 15, 2011 | 03:17 PM
I have seen 1 CTR in person and it was all OEM and I loved it.
Old Dec 15, 2011 | 03:42 PM
vietsol's Avatar
ek9 is a much better chassis. It has thicker front and rear sway bars and the chassis has been stitch welded to increase structural rigidity. To put a k in it, you have 2 mount kits to choose from. Ekk1 or ekk2. Ekk1 will put the motor in an awkward position but will allow you to run all original ek9 front suspension parts (sway bar, control arms, steering rack, subframe). Ekk2 will put the engine at a much better, lower, and more towards the back of the engine bay giving you better axle positions and better weight distribution, but you gotta get a dc2 or eg subrame/steering rack/control arms/sway bar to make that work.
as for weight, the k20 is about 45 lbs lighter than the b16b, but the k transmission weighs about 30 more lbs than the b. So weight savings will be about 10-15 lbs overall. The k has proven to be very impressive in ek/dc/eg cars at the track
Old Dec 15, 2011 | 03:45 PM
^ That might be one of the best responses I have seen to just about any thread on honda tech
F22AU
Apr 2, 2008 03:40 PM
CeeJayy
Jan 22, 2007 01:53 PM
Libertariat
39
May 18, 2005 01:30 PM
JSTOCK
Feb 28, 2002 05:38 PM
