THoughts on Osram 8000k HID kit VS. 4800K+ Philips HID kit
Old Oct 7, 2002 | 08:15 PM
PaChiLa Leader's Avatar
Default THoughts on Osram 8000k HID kit VS. 4800K+ Philips HID kit
Which one would you guys prefer?
I have G3 teg by the way
Old Oct 7, 2002 | 10:36 PM
:jdmshmaydm:'s Avatar
Default Re: THoughts on Osram 8000k HID kit VS. 4800K+ Philips HID kit (PaChiLa Leader)
I wouldn't buy the 8000k. That color temperature is too high (kelvin) therefore making it too blue. The 4800k will look more OEM and be a brilliant white light illuminating the ground. As the color temperature increases the less you will be able to see, because the lumens will go down as well. I have a 6000k kit and it looks good. I've been thinking about switching the bulbs for some 45-4800k bulbs, but I'm not sure. I think the 6000k looks more OEM in projector beams. At least it does in mine. And the illumination on the road is very good as well. Although it could be better with some lower kelvin bulbs.
EDIT: Tie-Poe
[Modified by Gatecrasher18AF, 11:39 PM 10/7/2002]
Old Oct 7, 2002 | 11:14 PM
Default Re: THoughts on Osram 8000k HID kit VS. 4800K+ Philips HID kit (Gatecrasher18AF)
Cool
and well say
thanks
yeah i always wanted to get 6000k philips kit but... this deal only has 8000k Osram which outputs Bluish.
we shall see
ANY HID is still HID.. and will be better than use the stock bulbs
Old Oct 8, 2002 | 12:43 AM
B2FiNiTY's Avatar
Blue? more like purple...
Old Oct 8, 2002 | 01:44 AM
comptechgsr's Avatar
Default Re: THoughts on Osram 8000k HID kit VS. 4800K+ Philips HID kit (ExOdy)
8000 is purple as hell
4800 is jus fine and classy lookin
benzo status
Old Oct 8, 2002 | 03:52 AM
Ricky Rojales's Avatar
Default Re: THoughts on Osram 8000k HID kit VS. 4800K+ Philips HID kit (comptechgsr)
Or, you could get a pair of Bosche HID (BMW), S2000, or Audi S4 projectors and swap them into your housing. You can use OEM D2S bulbs and achieve both the color/aberation and coverage of the vehicle the projector was originally designed for.
Old Oct 8, 2002 | 06:18 AM
BoM's Avatar
BoM
Default Re: THoughts on Osram 8000k HID kit VS. 4800K+ Philips HID kit (P)
where is a good place to get the 4300k or 4800, phillips.?
Old Oct 8, 2002 | 10:21 AM
um...
Old Oct 14, 2002 | 11:24 PM
MTK Kommander's Avatar
hmm.. osram only makes HID kits that comply with DOT.. 8000K rice kits dont comply..so i doubt osram made those 8000K POS's.. its probably some cheap company..
Old Oct 15, 2002 | 12:17 AM
zer0zer0 TypeR's Avatar
Default Re: THoughts on Osram 8000k HID kit VS. 4800K+ Philips HID kit (MTK Kommander)
my friend has an 8000K kit on his Supra and it looks NASTY. they don't even really look HID. they kinda look like those cheap NOKYA bulbs and when the light hits the ground it is too blue. definately go with anything under 5000K you'll like the results.
'00typer-who regrets getting 6000k, looks barney purple
edit:blocked license plate hehe
[Modified by '00TypeR, 1:19 AM 10/15/2002]
Old Oct 15, 2002 | 12:55 AM
Default Re: THoughts on Osram 8000k HID kit VS. 4800K+ Philips HID kit ('00TypeR)
yeah.. anything above 4300K doesnt look good at all..
Old Oct 15, 2002 | 01:37 AM
Holly Smokes~~~ Man.. that's really nasty
If i would go for i would stick with 4800~5100k now.... if your 6000k outputs like that.. then i wouldnt' want to bother the 8000k kit
Thanks for all the inputs guys..
I decided to stick with my 9005 SilverStar for now..
You guys are great..
have a good one
[Modified by PaChiLa Leader, 5:39 AM 10/15/2002]
Old Oct 15, 2002 | 01:47 AM
00TypeR what HID kit is that? Also, The Integra uses D2S bulbs if you were to switch them for some lower kelvin ones right?
Old Oct 15, 2002 | 02:27 AM
B2FiNiTY's Avatar
Definately does not look good.
Old Oct 15, 2002 | 02:39 AM
hell yea looks like *** it's the k2 6000K kit and i really don't feel like spending $150 to get some 4300K bulbs, i got to do other stuff first
Old Oct 15, 2002 | 02:42 AM
B2FiNiTY's Avatar
True...My friend with an accord has those...purple as can be. Definately not barney purple but a TRUE purple bulb UNLIKE seen on OEM kits.
chatman_55
Lighting
Dec 2, 2008 09:03 AM
g3teg97
Lighting
May 20, 2008 08:40 AM
integraautox
Dec 2, 2002 07:21 AM
TypeR1558
Sep 11, 2002 04:44 AM
is3oo
Jan 30, 2002 10:47 PM
