Dashboard brake light
Old Dec 14, 2011 | 04:52 PM
regular_guy_49's Avatar
Default Dashboard brake light
Hi,
The dashboard brake light appears whenever the weather gets cold. Has anyone else experienced this? Any suggestions please?
thanks
Old Dec 14, 2011 | 05:17 PM
6_Speed's Avatar
Default Re: Dashboard brake light
Have you checked the brake fluid level? If it's low could be an indication that your pads are worn.
Old Dec 15, 2011 | 04:27 PM
Lost Again's Avatar
Seen this post somewhere before.......Which "brake" light, can we assume it is the one like when the e-brake is on.....or is this the one on the "car icon".
Old Dec 15, 2011 | 06:35 PM
crazymikey's Avatar
Check all your lights work. I've come across on my previous Accords that dirty and corroded sockets and bulbs cause an intermittent bulb out, which triggers the light on the dash.
Check your bulbs and sockets, clean if necessary and replace any that look like they may be getting old.
Try that first. Like you said, it's mostly in the cold, so I think you've probably just got a corrosion issue which is easily fixed.
Let us know what you find.
Old Dec 15, 2011 | 07:16 PM
It's the e-brake light. thanks.
thanks for your response. i'll try your suggestion.
Old Dec 15, 2011 | 07:39 PM
crazymikey's Avatar
Since you just said it's the e-brake light, completely disregard my first post.
SCinCA
Oct 6, 2014 06:35 PM
professorman
Oct 27, 2013 06:28 AM
kornkid21792
Jun 4, 2009 01:16 PM
mashoutposse
Sep 5, 2005 01:05 PM
TurboTurtleGSR
Sep 23, 2002 08:53 PM
