civic experts only did headgasket wont start look
Old Dec 14, 2011 | 03:02 PM
donvito#1's Avatar
Default civic experts only did headgasket wouldnt start and now has no power
so i got a 93 civic with a d15b7 heres the story so the car kept overheating diagonsied it as being a head gasket, so i replaced the headgasket been doing this for years so i know whats up, anyways it was a rough start the first time i started it but , then everything went smooth ran good the car sat and idled for 30 minutes and everything was fine started it a couple times after that and started perfect so this morning i started it up and started up fine again ,well after that i finshed everything by reinstalling the p/s pump and hooked the exhaust back up, went to start it up and it keeps struggling to start will fire but wont start i got spark and fuel i noticed white smoke coming out the intake when i would stop trying to start it im stumped only thing that was differnet from the whole thing is the crankshaft pulley broke so i put a d16y7 pulley on it any info will help
Old Dec 14, 2011 | 03:23 PM
sfar785's Avatar
Default Re: civic experts only did headgasket wont start look
hows the timing? if they Y7 pulley is larger than the B7 pulley it will throw off your timing. Also, how's your spark? All 4 cylinders sparking?
Old Dec 14, 2011 | 03:25 PM
ek9kbomb'd's Avatar
10 Year Member
it sounds like you have a timing issue
Old Dec 14, 2011 | 03:29 PM
donvito#1's Avatar
if it was a timing issue why would it run good yesterday start perfect a couple more times start earlier today fine then all of the sudden it wont start
Old Dec 14, 2011 | 03:30 PM
sfar785's Avatar
it could have jumped teeth
Old Dec 14, 2011 | 03:33 PM
donvito#1's Avatar
all 4 are sparking and how would a pulley throw of the timing u can only move the dizzy so much
Old Dec 14, 2011 | 03:34 PM
donvito#1's Avatar
i can recheck but i dont think so usually the car will start but run like **** if it jumped a tooth
Old Dec 14, 2011 | 03:36 PM
sfar785's Avatar
it happens a lot...go check your timing
and no, my old B7 jumped 3 teeth before because i guess the belt was loose, the car wouldn't even start.
Old Dec 14, 2011 | 03:37 PM
cpl rampage's Avatar
base timing for the B7 is different than the Y7 (16deg vs 12), so adjusting the timing with a light will be off because you have the wrong pulley on there. but it shouldn't affect you starting up or not.
Old Dec 14, 2011 | 03:39 PM
donvito#1's Avatar
Originally Posted by cpl rampage
base timing for the B7 is different than the Y7 i believe, so adjusting the timing with a light will be off because you have the wrong pully on there. but it shouldn't affect you starting up or not.
i didnt think it has nothing to do with the situation
Old Dec 14, 2011 | 03:41 PM
Steezer's Avatar
hmm you said smoke coming out the intake? like air intake, intake?
sfar785's Avatar
i don't think it has a major effect on it, but the 2 pulley's are different sizes which means the harmonic balance is off and it'll eat your bearings :/
Old Dec 14, 2011 | 03:43 PM
donvito#1's Avatar
so this is gonna be my check list tomorrow first thing check compression this was my brothers car and he told me he drove it overheating for a little bit "so possible head warp" and i noticed a little pitting in the head so i already told him thats their a possiablty that need a diff head but it start and ran so good im just stumped
Old Dec 14, 2011 | 03:44 PM
donvito#1's Avatar
i know that but i just put it on to make sure everything runs and drives good as i had a spare pulley laying around
sfar785's Avatar
yeah, see if that head is warped as well...if it is, i got a Y7 head sitting in my garage that just needs to be taken apart/cleaned/reassembled and it'll run like new...
Old Dec 14, 2011 | 03:48 PM
donvito#1's Avatar
im not pulling the head of again if anything ill just find a b7 long block i can get them for like 200 and put a diff motor in
Old Dec 14, 2011 | 08:03 PM
donvito#1's Avatar
so i got it started and running idles good runs smooth but has no power when i try to take off it just bogs down and want to die wont move and when i let off the gas it idles smooth again so i got a couple questions first off could that d16y7 pulley just be to much weight and throwing everything off or does it have to do something with the timing???? btw checked the compression and got 150 across the board on a cold engine
Old Dec 15, 2011 | 02:30 AM
apexi_rsx's Avatar
no the pulley wont affect it. ignition timing needs to be set farther then whats marked on that y7 pulley because it only shows 12* u need 16*.
Old Dec 15, 2011 | 11:45 AM
donvito#1's Avatar
hmmm i dont think so if i advance the timing or not still wont change anything besides the idles changing still will die if i try to drive
Old Dec 15, 2011 | 11:51 AM
sfar785's Avatar
that's a vacuum leak
Old Dec 15, 2011 | 12:16 PM
donvito#1's Avatar
a vacuum leak wouldnt give the car any power???? and i mean no power , i can hit the gas while trying to drive and the motor just boggs down but when even go anywere
Old Dec 15, 2011 | 12:58 PM
sfar785's Avatar
i know if you have a vacuum leak it won't give your car any bottom end and it'll have an erratic idle
Old Dec 15, 2011 | 01:52 PM
donvito#1's Avatar
idles fine the car will sit and idle all day just when i put it in drive and try to drive it , it will just bog down right away wont go anywere
hollowman8904
Jan 7, 2009 08:59 PM
adamsjm5
Nov 8, 2006 07:00 PM
CivicHP
Jun 1, 2005 02:27 PM
bonestock92si
38
Aug 30, 2004 10:02 PM
