were to buy 38mm 3m thick pipie
Old Dec 14, 2011 | 11:30 AM
hoochhenry's Avatar
Default were to buy 38mm 3m thick pipie
any place to buy this pipe mild steel for manifolds can i bend it easy enough in a cheap bender mybe to do 180 degree bends and so on ,any help would be great
Old Dec 14, 2011 | 01:59 PM
k24em2's Avatar
Default Re: were to buy 38mm 3m thick pipie
how cheap is said cheap bender
Old Dec 14, 2011 | 10:24 PM
McRussellPants's Avatar
45,000 dollars is cheap to the 1%'ers I geuss?
Old Dec 15, 2011 | 09:59 AM
CRMB's Avatar
OG Fabricator
38mm, 3m tube = 1.5" OD x 0.120 wall. Most pipe fittings are 0.75 * diameter radius for short radius and 1.3 * diameter for long radius.
Since we talking about radiuses less then 2D - which are extremely difficult to bend - I'm going to assume you are only looking for a machine top condition - so we will look at new.
Short fittings you would need 85,000 ft*lbs of torque, which is about a #6 sized machine --- so about $300k+.
For long radius @ 1.3*diameter radius you need 32,000 ft lbs of torque.. So maybe a #3 sized machine which should be 150-200k tops.
Cheap right?
Old Dec 16, 2011 | 04:02 AM
Boosted_B_Series's Avatar
Nice
hatchy
May 4, 2003 11:42 PM
underpressure02
Oct 14, 2002 12:22 PM
spoolin342
Honda Motorcycles
Feb 23, 2002 01:05 PM
