Made tuning appointment - help me with prep-checklist pls?
Old Dec 14, 2011 | 09:32 AM
DSMAddicted's Avatar
Default Made tuning appointment - help me with prep-checklist pls?
Guys,
I made an appointment to have the little beast tuned by Kenny (Turbogixxer).
Car (tuning related stuff):
  • '93 Hatch with JDM ITR swap
  • Buddy Club adjustable Cam Gears
  • Chipped P28 with base ITR map
  • 3" SRI/BPi velocity stack/K&N Filter
  • RMF Narrow replica header
  • Apex'i WSII
Performed during the swap (about 9 months ago):
  • Cleaned injectors (cleaned by Cruzinperformance.com)
  • New timing belt, seals, water pump, VC gasket and related items
  • New fuel filter
  • New fuel tank (upgraded to a 11.5 gallon, so I know it's clean/no gunk)
To be performed right before tuning:
  • Fresh oil and filter
  • Valve Adjustment (and installing a temporary cut valve cover for cam gear access)
  • Fresh set of NGK PFR6G-11
  • New OEM spark plug wires
  • New OEM distributor cap and rotor
  • Check and replace/clean ALL grounding points in the bay
  • Clean battery contacts (Optima Yellow-top)
Anything else I might be missing?
Thanks for the help with the brainstorming.
Old Dec 14, 2011 | 09:40 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Made tuning appointment - help me with prep-checklist pls?
I think it would be best to run this by your tuner.
Old Dec 14, 2011 | 10:04 AM
I did. We can't think of anything else.
But I figured it would be beneficial to list everything in one spot and ask for the community's input.
The cam gears, for example, were a last minute thing (he was convinced I already had adjustable cam gears).
-Walter
Old Dec 14, 2011 | 10:07 AM
Linked's Avatar
i've heard that putting a car with a bad alignment on a dyno can be highly dangerous, is the car aligned?
Old Dec 14, 2011 | 10:12 AM
BryanM.'s Avatar
Resident Gearhead
Maybe Ohm the coil? I can't think of anything else lol
I was going to say fuel new fuel tank but you already did it.
Old Dec 14, 2011 | 10:33 AM
Yes, she's aligned.
I have very slight dog-tracking in the rear (possibly bad TA from disc conversion), but the front is good.
You mean to check it for resistance?
Yes, I was surprised though, even the old 9.9 gallon tank was very clean inside.
At least I know for sure.
Good thoughts guys, thanks for the suggestions and keep them coming.
Old Dec 14, 2011 | 10:39 AM
BryanM.'s Avatar
Resident Gearhead
Right
Old Dec 14, 2011 | 11:36 AM
10psiLsEf2's Avatar
full tank
gap plugs
Old Dec 14, 2011 | 12:06 PM
Originally Posted by 10psiLsEf2
full tank
gap plugs
Full tank for good, homogeneous pressure I suppose? Makes sense.
And gap... definitely, thanks.
fortworthmatt
Aug 15, 2015 02:47 PM
forevermemorabl
19
Sep 25, 2013 10:54 AM
bboixtc
Nov 5, 2006 10:28 AM
KND
Jan 15, 2004 08:09 AM
Behan
Jul 8, 2003 02:09 PM
