pr3 ecu on a B18C
Depends on what pr3 it is, obd1 or obd0, you will need the corresponding harness to be able to use it. You are better off with a p72 as it has the option to control the butterflies. WitH all other ecus, you will most likely need to disable the secondary butterflies in the GSR intake manifold and/or get a b16/itr style manifold, such as the skunk2 or blox.
speedyR
Feb 18, 2004 01:30 PM
